how do i adjust boost
Old Apr 24, 2003 | 09:05 PM
Kazz's Avatar
Default how do i adjust boost
I have a greddy turbo for a GSR and was wondering what the safest boost level if my motor is stock beside 5psi. how high can i go and how do i adjust it?
Old Apr 24, 2003 | 09:08 PM
MiraiZ's Avatar
Default Re: how do i adjust boost (JuuKe_EM)
intercooled?
Old Apr 25, 2003 | 07:11 AM
Kazz's Avatar
Default Re: how do i adjust boost (MiraiZ)
Yes i have a spearco intecooler too. Do i need to adjust timing or does the blue box do that?
Old Apr 25, 2003 | 07:27 AM
soundman's Avatar
If your motor is stock, I wouldn't run more than 6 because that motor has high compression. You need to get a boost controller to control your boost, and if you dont have one, you definitely need a boost gauge. You should get an oil pressure gauge, and an air/fuel gauge just for insurance. As far as a boost controller, you could get a manual one which consists of a ball and spring valve, or you could get a costly electronic controller. I got my boost cotroller off Ebay for $17.
Old Apr 25, 2003 | 07:29 AM
94dxt's Avatar
boost controller, no on timing-turn back manually/btm/management/etc., 7psi w/ a pump some say higher (i am not familiar with the gsr kit)
Old Apr 25, 2003 | 09:41 AM
mamaboy's Avatar
Build a manual boost controoler for $6.00
http://www.c-speedracing.com/howto/mbc/mbc.php
Yeah try that out....and you'll be fine in 8psi range if you tune it completely...air/fuel...timing etc.....and you have your intercooler so you won't detonate correct..with lower charged air?...I would assume that's why you have the intercooler....Greddy GSR kit with Intercooler raises boost to 8psi....chill and you'll be fine...tune tune tune...boost boost boost. Get a boost gauge as well so you can get it right on the dot...Somebody used this I remember a couple weeks ago and said the boost held perfectly.
Old Apr 25, 2003 | 10:22 AM
DBallz's Avatar
This is comming from someone who owns a Greddy kit and blew his first motor. You don't need a fuel pump, but if you plan to raise the boost past the 5psi spring then you want to get a boost controller and gauges. Also the blue box only controls fuel the ignition is still the same. You might either want to retard the timing 2-5 degrees or get yourself a MSD BTM. If you don't you stand the risk of blowing your motor. It will be your ring lands that go first.
Integra21
May 21, 2006 04:16 PM
Integra21
May 21, 2006 04:15 PM
zccr-xsi
Mar 22, 2006 06:26 PM
alpha
Sep 26, 2005 09:09 AM
Ray
Jul 7, 2001 07:34 PM
