how to...compressor maps
Old Dec 7, 2001 | 09:39 AM
jacobkatz's Avatar
Default how to...compressor maps
i was wondering how to read compressor maps, what they tell, and how to apply them for you own application?
ok thanx
Old Dec 7, 2001 | 09:54 AM
Tomakit's Avatar
Default Re: how to...compressor maps (jacobkatz)
grrr...
there was a thread that had the most relevant info to your question that was active here less than 24 hours ago!
look around some.
Tom
Old Dec 7, 2001 | 06:05 PM
BlueShadow's Avatar
ok thanx
https://honda-tech.com/zerothread?id=96443
close to the bottom look for my post
EDIT: here I just cut-and-paste all the info.
if you want to learn how to read compressor maps and calculate compressor sizes I'll be more than happy to show you.
What you need to do is find you airflow rate based on : your desired boost (PSI) engine size and engine redline. you need to find your Airflow rate at two points first point is at redline second point is usually at 75% of redline or where ever the compressor hits full boost, whichever is at a lower RPM. All you need to know is basic math, add, subtract, multiply and divide. you'll deal with different units of measurement (lb,cfm,psi) lets start:
Basics you will use these numbers later on
PRESSURE RATIO = (14.7 + desired PSI) / 14.7 = PR
convert CFM to LB per MIN = CFM x 0.070318 = LB/MIN (@ sea level and 112 degrees*)
LITERS TO CUBIC INCHES DISPLACEMENT = # of L's x 61
CFM = Cubic Feet per Minute
now using my car as an example:
2.2L (134.2 cid), 7400 Redline, desired boost is 10 PSI
#1 CALCULATING AIRFLOW RATE AT REDLINE and 10 PSI
cid = Cubic Inches Disp.
VE = Volumetric efficiency in percent
.5 = (given) 4-stroke engine fills cylinder only on one-half the revolutions
1728 = converts cubic inches to cubic feet
Airflow in CFM = (cid x rpm x .5 x VE%) / 1728 = CFM no boost
CFM x PR = CFM under boost
so for my Lude:
PR = (14.7 + 10 ) / 14.7 = 1.69
Airflow = (134.2 x 7400 x.5 x .95) / 1728 = 272.99 CFM (no boost)
272.99 x 1.69 = 461.21 CFM under 10 PSI
now since most compressor maps have their flow rates in LB/MIN we need to convert CFM to LB/MIN. A cubic feet of air (length+width+height) weighs different at diff. Altitudes and different temperatures. to simplify it well just assume we are at sea level and the air temp is 112 *. the conversion number is 0.070318.
so for CFM TO LB/MIN = CFM x 0.070318 = LB/MIN
461.21 x 0.070318 = 32.44 LB/MIN
so here we have:
BASIC ENGINE FLOW RATE = 272.99 CFM
ENGINE FLOWRATE with 10 PSI = 461.21 CFM (32.44 LB/MIN)
PRESSURE RATIO (PR) = 1.69
so now we know our flow rate in LB/MIN
a 2.2L with 10 PSI of boost at 7400 RPM (redline)
flow rate = 32.33 pounds of air per minute (LB/MIN)
PR = 1.69
with me still? this is POINT NUMBER ONE. now we do the same for 75% of redline and 50% of redline.
#2 CALCULATING AIRFLOW RATE AT 75% RPM RANGE
now we will find the airflow rate at 75% redline = 5550 RPM (0.75 x 7400 = 5550)
(134.2 x 5550 x .5 x .95) / 1728 = 204.74 CFM no boost
204.74 x 1.69 = 346.02 CFM under 10 PSI
346.02 x 0.70318 = 24.34 LB/MIN
BASIC ENGINE FLOW RATE = 204.74 CFM
ENGINE FLOWRATE with 10 PSI = 346.02 CFM (24.34 LB/MIN)
#3 CALCULATING AIRFLOW RATE AT 50% RPM RANGE
As you may already know the point at which the compressor reaches full boost is largely determined by the Turbine side. but I usually calculate a third point just incase. I plot this third point on the compressor map this way if boost comes way early (50% redline) I know where I lie on the map.
50% of redline = 3700 RPM (0.50 x 7400 = 3700)
(134.2 x 3700 x .5 x .95) / 1728 = 136.50 CFM no boost
136.5 x 1.69 = 230.69 CFM under 10 PSI
239.69 x 0.070318 = 16.23 LB/MIN
BASIC ENGINE FLOW RATE = 136.5 CFM
ENGINE FLOWRATE with 10 PSI = 230.69 CFM (16.23 LB/MIN)
GATHER YOUR DATA
we have just figured out our engine's airflow rate at 3 RPM points (redline, 75% and 50%) you only need 2 at the minimum but you can use as many points as you want.
<U>POINT 1 (7400 RPM)</U>
<U>POINT 2 (5550 RPM)</U>
<U>POINT 3 (3700 RPM)</U>
these are the three points you will start referencing onto the different compressor maps, ideally you want all three to be within the highest percentile in the compressor map.
using this map of a T04E 60 trim first let me explain all the numbers on the map
1-left side, pressure ratio
2-bottom side, airflow rate (LB/MIN on this map)
3-dotted line on far left side of "ovals", surge limit
4-numbers on far right, 46020, 69640, 83972 etc, compressor RPM (yikes)
5-78%,75%, 74%, compressor efficiency, this is related to the temp of air, a low number (60%) means that the compressor is heating the air more a high number (78%) means the air is not heated as much when it is compressed.
NOW all you have to do is take the each RPM point and put them on the compressor map, use the airflow rate and PR wherever they intersect is where the point will go. ideally you want all points to be in the highest Comp. Eff. %, especially the redline and the 75% redline points.
go ahead and give it a trry, but thats pretty much how you select compressors if any of the points lie:
-in a low Comp Eff %
-in the surge limit
-too high a Comp. RPM
you need to look at a different Compressor map cause the one your looking at is the wrong size, each Compressor trim has its own compressor map.
FIND THE SURGE LIMIT LINE
you also need to draw /find the surge limit line.
its easy all you do is go to the bottom of the compressor map and draw a line from
PR = 1 and airflow rate = 20% of maximum, and draw a line from that to the RPM point at which full boost starts 3700 and 5550, as long as this line stays to the right of the surge limit you're ok. this line represents your rpm line from zero PSI to full boost (10 PSI)
so from PR = 1
and flow rate at idle:
max flowrate x .20 = idle flowrate
461.21 x .20 = 92.25 CFM
92.25 x .070318 = 6.5 LB/MIN
PR = 1
airflow @ idle = 6.5 LB/MIN
draw a line from that to the points at 50% (3700 RPM) and 75% (5550 RPM)
let me know if you need anything explained, its no problem
[Modified by BlueShadow, 3:17 AM 12/8/2001]
[Modified by BlueShadow, 3:20 AM 12/8/2001]
Old Dec 7, 2001 | 06:47 PM
Giuseppe's Avatar
Default Re: how to...compressor maps (BlueShadow)
http://www.badbricks.com/main_files/faqs/turbo_size.htm
its here too
HTH
Old Dec 7, 2001 | 07:54 PM
BlueShadow's Avatar
Default Re: how to...compressor maps (Giuseppe)
me and that guy used the same exact source Corky Bells book "Maximum Boost"
so what he says and what I have typed is virtualy identical. the plus side is if any of this stuff is confusing to you guys I can walk you through it. or if you give me your specs I can show you how to do your own car, all I would need to know is:
-engine size in liters
-your redline
-VTEC or NON VTEC
-what boost you plan on running
I also noticed several things about that site, he said he used 85% as his number for Volumetric efficiency but I used 95%. I'll tell you my reason for using such a high number in a minute.
If you used a calculator and check over my work you'll notice a small discrepancy. I round all my numbers up. for example if my equation for airflow comes out to 35.123101 LB/MIN I will round up to 36 LB/MIN, same with boost/pressure ratio 1.6801347 will go up to 1.69 (1.7 would be better)
I did that to give myself some margin for safety, that way when you are trying to get the right fuel mixture your using a higher volume of air (36 vs 35.123101) .
that extra pound of air that I just rounded over might help against detonation because with an increase of 1 pound of air in the airflow we have to add XXX amount of fuel.
same thing goes with the Volumetric efficiency, its hard to figure out exactly what it is at a given RPM so I use the max 90-95% this means that we are accounting for more air entering the engine.
for example:
my car 2.2L(134.2cid) at 7000 RPM at 80%VE and 95%VE
80% Volumetric efficiency
(134.2 x 7000 x 0.5 x .80) / 1728 = 218 CFM with no boost
thats 368.43 CFM at 10 PSI or 25.91 LB/MIN
95% Volumetric efficiency
(134.2 x 7000 x 0.5 x .95) / 1728 = 259 CFM with no boost
thats 437.72 CFM at 10 PSI or 30.78 LB/MIN
So you see a 15% difference between VE means a 5 lb difference in airflow!
so think about it, your doing fuel for 25.91 LB/MIN (80%) but what if your getting mroe air then that? what if you were actually getting 30.78 LB/MIN (95%) but were only adding enough fuel for 25.91 LB/MIN?
BOOM! detonation!
[Modified by BlueShadow, 4:55 AM 12/8/2001]
Del_Slowest
May 26, 2004 08:08 AM
boosted_zc
May 7, 2003 10:21 PM
43MA
Apr 24, 2003 10:35 AM
vtec.dc2
Jan 9, 2003 09:14 AM
