How big should sleeve?
Old Jan 5, 2003 | 06:34 AM
GEN2TEG's Avatar
Default How big should sleeve?
Currently i am debating how big of a sleeve i should go in my b18a. Ive been thinking to go 84mm but ive been told i need to modify the head and then if god forbid anything happened to my block i would essentially needs a new one.
What's should i do guys HELP! Im leaning to maybe an 83mm sleeve so that in case something does happen i am safe.
Old Jan 5, 2003 | 09:18 AM
E Swift's Avatar
Default Re: How big should sleeve? (GEN2TEG)
I've heard that the larger you go, there's a chance it may ping. Don't quote me on that, but thats what I was told when I considered doing it.
Old Jan 5, 2003 | 09:39 AM
jinxproof99's Avatar
New User
Default Re: How big should sleeve? (E Swift)
84mm for turbo.
Old Jan 5, 2003 | 09:44 AM
ninesecteg's Avatar
84mm is fine to run. the only problem is if something goes wrong (torched piston) it doesn't leave you a lot of room to clean up the damage that it has done. you can run 85mm but 86mm is pushing it. but then again if only one sleeve gets damaged you can always get that single sleeve replaced. you can always get the block resleeved again, it will never be scrap. oh yeah take into consideration the fact that by increasing bore size can increase C/R. turbo apps. try to keep bore size at 84 or under just to be safe.
Old Jan 5, 2003 | 11:14 AM
GEN2TEG's Avatar
Default Re: How big should sleeve? (jinxproof99)
84mm for turbo.
Is it true though that you have to modify the head? I have been told that you would have to do so. I am running an LS/VTEC turbo.
Old Jan 5, 2003 | 11:47 AM
avividmemory's Avatar
Default Re: How big should sleeve? (ninesecteg)
i would stick with 83 for now, in case something does happen and you have to bore, theres a little more room for error...
and then you can buy my custom 83mm je's
Walterronny
Honda S2000
11
Oct 29, 2013 07:29 PM
beasty=eg
Aug 29, 2008 09:24 PM
laziebun
May 7, 2008 08:16 AM
penjaja
Mar 23, 2003 08:17 PM
