How bad is it to run lean under part throttle?
Old Mar 17, 2004 | 05:25 PM
5thgencivic's Avatar
Default How bad is it to run lean under part throttle?
I just realized today I've been running lean under part throttle. Hondata is in closed loop as well. It was a little like this before, but more so now that I switched back to an OEM o2 from a bosch. The car will bog when taking off in first and it makes it hard to drive. I'm getting insane gas mileage this tank and I've been boosting the same as before. Gas mileage has gone up almost 10 miles per gallon since switching the o2. I've already gone 194 miles and the needle is right about half way. Which would be about 38.8 miles per gallon I bumped the fuel pressure up about 3-4psi and it should be ok until I can make it to the tuner. So how harmful is it? I should have realized it before
Now that I think about it, I've been hearing my walbro more now too. I hope it's not taking a dump, it's only 3 months old.. Thanks.
Nate
Old Mar 17, 2004 | 11:56 PM
Nick7's Avatar
Default Re: How bad is it to run lean under part throttle? (5thgencivic)
If you're at part throttle and in closed loop... yr ECU aims for 14.7 A/F ratio... nothing to worry there.
Start to worry if you're in open loop and lean out
Old Mar 18, 2004 | 06:10 AM
tgreaves's Avatar
Default Re: How bad is it to run lean under part throttle? (Nick7)
Yes.. If you had something screwie with your o2 sensor before the ecu might not have been going into closed loop.. But now that it is thats why your getting the good gas mileage..
Old Mar 18, 2004 | 06:46 AM
Default Re: How bad is it to run lean under part throttle? (tgreaves)
I didn't even get this good of gas mileage when the motor was completely stock with the stock ecu Like 4MPG less than this tank now babying it with the stock motor. And I've been boosting plenty on this tank.. Just by raising the fuel pressure it doesn't bog from 0-25% throttle anymore. Wouldn't that mean it's lean?
Old Mar 18, 2004 | 06:47 AM
legendboy's Avatar
The only time you need to worry about running lean at part throttle is if your part throttle boosting. If your not in boost then its fine.
D16SiHatch
Dec 29, 2008 06:22 PM
aZnjCC
11
May 23, 2006 01:39 PM
fafsa
Mar 4, 2005 03:00 PM
BorderM3
Apr 2, 2003 11:38 PM
disordeR
Dec 29, 2002 11:48 AM
