hooking up boost guage???
Old Aug 17, 2003 | 07:15 PM
ATS*Mark's Avatar
OG triple OG
Default hooking up boost guage???
where does the vacum line hook up too , it doesnt look like theres enough line that came with the guage to go to the turbo , can i get a longer hose from like home depot or somthing??? this is an autometer mechanical vac/boost guage...
Old Aug 17, 2003 | 07:18 PM
vtec.dc2's Avatar
Default Re: hooking up boost guage??? (TURSpoonEK)
mine is connected to intake manifold, the same hose that connects to wastegate, get a t-fitting, - all that you can find at autozone type stores..
Old Aug 18, 2003 | 07:34 AM
ATS*Mark's Avatar
OG triple OG
Default Re: hooking up boost guage??? (vtec.dc2)
where in the intake mani??? i dont have my car here to look at it and i cant remember where the wastegate hooks to
Old Aug 18, 2003 | 09:40 AM
1990hondaHF's Avatar
Just use a "T" fitting and run it off another vacuum line.
Old Aug 18, 2003 | 04:11 PM
ATS*Mark's Avatar
OG triple OG
Default Re: hooking up boost guage??? (1990hondaHF)
any vacum line????
ATS*Mark's Avatar
OG triple OG
and my guage came with that small hard plastic line , could i buy rubber hose and use that??????
Old Aug 18, 2003 | 04:19 PM
alpha's Avatar
You could also "tap" the back of your intake manifold.
Old Aug 18, 2003 | 11:30 PM
psileepR's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURSpoonEK &raquo;</TD></TR><TR><TD CLASS="quote">any vacum line????</TD></TR></TABLE>
ya... but to keep it clean u might as well choose the closest vacuum line to the gauge and/or gauge sensor
Old Aug 19, 2003 | 05:21 AM
ATS*Mark's Avatar
OG triple OG
Default Re: hooking up boost guage??? (psileepR)
ya , ill do that
Old Aug 19, 2003 | 05:26 AM
ricodemus's Avatar
Is this the purpose of running a Vacuum manifold? So you can just run lines to what - Turbo, wastegate, boost controller, boost guage? Sorry, I'm a little confused.
Old Aug 19, 2003 | 11:19 AM
psileepR's Avatar
New User
Default Re: hooking up boost guage??? (ricodemus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricodemus &raquo;</TD></TR><TR><TD CLASS="quote">Is this the purpose of running a Vacuum manifold? So you can just run lines to what - Turbo, wastegate, boost controller, boost guage? Sorry, I'm a little confused.</TD></TR></TABLE>
yes but remember that the more sources you plug to a vacuum block the weaker each source's signal will be. So make sure u have a big enough vacuum on the little block port to supply all your attatchements.
Old Aug 20, 2003 | 06:16 PM
ATS*Mark's Avatar
OG triple OG
ex motors(dont know if other IM's have it. have a vacum port on the back of the manifold that doesnt go to anything , i hooked my guage up there and works perfectly
drintegra
Apr 13, 2006 03:58 AM
Acura_I-RS
Mar 29, 2003 03:25 PM
kickz
Aug 8, 2002 04:35 AM
Pengo
Jul 23, 2002 09:35 AM
greyzone
Nov 11, 2001 05:06 PM
