hondata vs somehting else
Old Jul 16, 2002 | 05:43 PM
Urban Business
Guest
Posts: n/a
Default hondata vs somehting else
im seeing one main problem w/ the hondata. i cant modify anything on the fly. ie id have to burn a new rom every time i wanted to change somehting. am i way off base w/ this theory? i was planning on boosting my 1.5L but wanted to run a dual setting boost controller, afc and ignition. i also want to be able to mod it on the fly. ive looked at the hond data and for a grand i can run stand alone everything. :shrugs:
Old Jul 16, 2002 | 05:58 PM
MiraiZ's Avatar
Default Re: hondata vs somehting else (TorteX)
I recommend Power FC...but you may have issues with the harness...
Old Jul 16, 2002 | 06:02 PM
BoostingLS's Avatar
i like the HKS F-CON cause there are 4 different settings you can have.
Old Jul 16, 2002 | 06:05 PM
tygsr's Avatar
Default Re: hondata vs somehting else (BoostingLS)
its all about the AEM EMS...
Old Jul 16, 2002 | 06:07 PM
AB16A2T's Avatar
Default Re: hondata vs somehting else (tygsr)
I too like the AEM EMS, I am getting it for my car seeing as I am staying SOHC it means I dont' have to do an OBD2 to OBD1 conversion. And I believe you can modify it on the fly if you buy the software and have a laptop.
Old Jul 16, 2002 | 06:08 PM
Sonny's Avatar
Why not Zdyne? Lack of datalogging aside, it's a good standalone for the OBD0 crowd. You can run Hondata on your car (what is your car, btw) and no, you do not need to burn a chip every time you want to make a program change. You can run your car off of the emulator and make changes quickly until you are done tuning. When you make a change, you just download the changes into the emulator and away you go. It's fast, easy, and no chip burning is required. When you are done tuning, then you reburn your existing chip. Works for me.
Sonny
Old Jul 16, 2002 | 07:14 PM
dustin's Avatar
Default Re: hondata vs somehting else (Sonny)
AEM EMS or Zdyne
Old Jul 16, 2002 | 07:48 PM
Dee's Avatar
Dee
Default Re: hondata vs somehting else (dustin)
Without the Datalogit software the PowerFC is a pain in the ***. Zdyne or AEM.
Old Jul 18, 2002 | 02:43 PM
Urban Business
Guest
Posts: n/a
Default Re: hondata vs somehting else (Dee)
coo coo. i was going to run the msd digital sci for timing (dual settings) safc for fuel (dual settings) and prolly a blitz boost controller (havent worked that out yet).
R THIS
Mar 1, 2012 11:55 AM
clean4dr
Dec 6, 2006 05:58 AM
Solo1
Sep 20, 2003 11:00 PM
MyLittleRedCar
Sep 5, 2003 02:43 AM
98civicguy
Apr 8, 2003 07:24 PM
