HONDATA tunners another question
Old May 24, 2006 | 02:46 PM
JDMCRX's Avatar
Default HONDATA tunners another question
OK my car is all ready to go two questions.
One how do i datalog and monitor the AIR FUEL on the computer . Does it allow you to see the air fuel ratios recorded in there exact spot??
2. How do i convert you know in the DISPLAY mode were u see MAP,TPS and the last one is LAMBA can i convert that one to AIR FUEL??
Old May 24, 2006 | 02:48 PM
JDMCRX's Avatar
Default Re: HONDATA tunners another question (JDMCRX)
Like to datalog and record the settings do i just hit record and go to the SHOW RECORDED/DATALOGGED LAMBA
and it will record it there???
Old May 24, 2006 | 09:03 PM
JDMCRX's Avatar
OK did some dataloggin with ELSPOOL. I had set the air fuels to 11.5 when i hit 7,000rpm plus they go to 10.84. But when i datalog the recordings show this look at the 8psi graph.
Also how do i change the lamba display to the air fuel 14.7 stoich
Old May 24, 2006 | 09:08 PM
mrbsponge's Avatar
i have tried "clicking" the A/F box and have still only been getting lamda readings, if that was the AF recorded then you would need to richen it to achieve your goal, but honestly 12.0 is fine
Old May 24, 2006 | 09:11 PM
JDMCRX's Avatar
Default Re: (mrbsponge)
OK ill try refreshing my air fuel up top is to rich 10.84
Old May 25, 2006 | 06:20 AM
Too_Smooth's Avatar
Default Re: (JDMCRX)
1. Go to options
2. Sensors
3. Under that list look for AF (air/fuel)
4. Change the unit type from Lambda to Air/Fuel
5. Make sure you change the display Min and Max also.
Old May 25, 2006 | 06:33 AM
JDMCRX's Avatar
Default Re: (Too_Smooth)
Yeah i did that but i did not change the setting i put it as 10 low and high 18
Chops13
Engine Management and Tuning
Jun 16, 2013 07:25 PM
HooFu
Mar 17, 2009 06:59 PM
Benjithx
Jan 13, 2005 10:08 AM
AzNsTyLe361
Jan 12, 2005 06:50 AM
ZCHF
Mar 1, 2003 03:20 PM
