got my pistons and rods in!! A few q's...
The rods are stamped with numbers. Do these numbers mean anything? Are the rods installed with those number sides facing toward the dipstick and are they installed in a certain order?
The pistons are CP and the valve grooves are deeper on one end, these are the intake sides right?
Re: got my pistons and rods in!! A few q's... (zerovandez)
in my experience the rods are stamped 1-4 to make it easy to identify which is for which cylinder.
the larger valve reliefs are probably for your intake side - check your head and match up the valves. or refer to your stock pistons.
Re: (JDMCRX)
Honda Rods have 4 sizes the numbers stamped on the original rods are there to tell you what size the big end bore is.
Rods are not directional only pistons unless they are flat tops. The most important thing is to gap the rod bearings and the piston rings for your application.
d16dcoe45
09-27-2006 05:15 PM
TheSwift1
10-26-2002 09:27 PM
