hondata tuning
i plan on installing my turbo within the next few weeks, and i was looking for a <U>REALLY</U> good hondata tuner on the east coast. preferably between New Hampshire and New York. I live in Rhode Island but for the sake of my car i will travel to an extent. MA,CT,NY,NJ,NH would be preffered. any help would be great. thanks in advance
[Modified by itr449, 9:59 PM 12/1/2002]
I have a two base maps that i can offer if you'd like. My engine is a poor man's itr engine (b16a/gsr bottom end) and low compression (8.8:1) with 720cc injectors. It wont be right (no map will ever be perfect), but it probably will get you into the ballpark. I both of them street tuned, and my most current map i am running my 60-1 t3 on 14lbs daily driven on pump gas with no signs of detonation making at least 350whp, stock internals.
Make a trip to sunny Florida. Vaportrail will tune your Hondata.
Probably not that great, and with your compression timing is going to be the key to tuning that engine. I would just spend the money and find a good hondata tuner in your area. Check out hondata's web site and see their listing for dealers, they are usually tuners of the system as well. Hondata is so easy to tune, its quite hard to mess things up unless you have no tuning knowledge at all. Good luck.
what base map you have in now ?i can burn you the base map for a price from hondata for an R with a 10psi drag kit on it and then from there just fine tune it on the dyno , thats prob what im gonna work with on mine
i haven't got the system yet. i'm just trying to line everything up for when i do the install.
Gruvytune, we spoke a few months ago. i had a brain fart and forgot about you. i think i'll hit you up
i was cruising around the hondata website and found a place here in new england, about an hour away from me. i'm gonna take it there. i think its called Performance Race Equipment. i'll post the progress of the set up. thanks for all the suggestions
