hondata or tranny?
Old Jan 30, 2003 | 10:49 AM
mrod006's Avatar
Default hondata or tranny?
i need some opinions here. I have a greddy powered sohc Y8 with stock internals. One slight problem: My car is an automatic. should i get hondata first to make the engine more reliable or should i beef up my tranny first?
Old Jan 30, 2003 | 11:00 AM
swrdply400mrelay's Avatar
Default Re: hondata or tranny? (mrod006)
What are you running for fuel management right now?
BTW, where in SA are you from anyways?
Old Jan 30, 2003 | 11:26 AM
blu_si's Avatar
Default Re: hondata or tranny? (swrdply400mrelay)
Yeah whats your management now? I would say get the hondata, cause if you're gonna swap in a manual tranny, you're gonna wanna mash on it. And you don't want to see white smoke comin from your motor after boosting.
[Modified by blu_si, 12:26 PM 1/30/2003]
Old Jan 30, 2003 | 03:03 PM
mrod006's Avatar
Default Re: hondata or tranny? (blu_si)
i am running the blue box now, but i want to keep my auto tranny.
mrod006's Avatar
northwest side, near jeff high school.
Old Jan 30, 2003 | 03:39 PM
blu_si's Avatar
Then get hondata first and do away w/the blue box.
Old Jan 30, 2003 | 04:05 PM
ekb18c's Avatar
Hondata will not work with auto cars.....
sorry
Old Jan 30, 2003 | 04:17 PM
ill_take_one's Avatar
Default Re: hondata or tranny? (ekb18c)
Yeah, hondata doesnt mix with the automatics.
Not to dampen your spirits anymore, but goodluck with the auto tranny...
I was in the same boat, ready to boost, debating for almost 2 years whether to do so, but after all the horror stories i've heard, i'm not even going to mess with it.
The valve bodies of the honda auto are the weakest link, and not a company that i know of makes parts to beef em up.
you can upgrade the torque converter and other parts as much as you want, but its like like a weak link in a chain. it only takes one part to make the whole tranny fail.
Peace, and goodluck
Just boost in moderation
Old Jan 30, 2003 | 09:26 PM
Spunkster's Avatar
Default Re: hondata or tranny? (ill_take_one)
He can use a Stage 2b or stage 3b with an auto tranny. HE just can't use the s100 or s200.
Old Jan 31, 2003 | 06:24 AM
mrod006's Avatar
Default Re: hondata or tranny? (Spunkster)
yeah, i was planning to use the 2b. so the 2b would work in my case?
Old Jan 31, 2003 | 07:15 AM
I'm pretty sure it would.
But plan for a tranny swap later too. My friend's prelude's tranny started to give out after about 6 months after being turbo'd, so he got a tranny swap.
Damn I know a lot of Mike Rodriguez's.
Old Jan 31, 2003 | 07:58 AM
ExospeedAMcrx's Avatar
yadont expect to take the auto trans to the limit. it wont be able to handle it. honda auto trans and turbo just doesnt mix. there are alot of weak parts on the auto trans. but if the auto trans does give out.. its not like a honda trans is expensive.
OT: i had a valve body give out on my 2000 BMW 323 and it cost $1500 just to fix part of the problem... thats when I started hating european cars..
Old Jan 31, 2003 | 08:48 AM
mrod006's Avatar
Default Re: hondata or tranny? (exospeedAMcrx)
i am not going to push it. around 5 psi. daily and once in a while 7 for track days. would that be pushing it?
Old Feb 1, 2003 | 08:41 PM
Mr.DC2TurBo's Avatar
5psi? Damn, what's the point of having a turbo then on your auto.. You are not even making 150hp at the wheel with that greddy kit. 7-9 psi is fine put I don't even think your greddy slush box will allow you to boost that high without throwing some kind of code. But off the subject, how will know if your transmittion is starting to slip for an automatic?
Old Feb 1, 2003 | 08:47 PM
sharkcohen's Avatar
Any amount of boost will be pushing it. Take that for what it is worth, from someone who is boosting on an auto. Boost involves risk, and boosting on an auto involves even more risk.
Old Feb 2, 2003 | 10:48 AM
Default Re: hondata or tranny? (LS-T2001)
What the hell? Please go into more detail why you think this..
Anyway, you'll know if your tranny is slipping. If it slips out of a gear once and awhile, or doesnt even go into certain gears. Also, if your revs jump inbetween shifts too. Thats when you better start worrying.
Peace
done
May 14, 2005 02:13 AM
22vtec
Oct 18, 2004 01:58 PM
mrod006
May 9, 2003 03:27 PM
Spunkster
Feb 10, 2003 11:13 PM
Aeka GSR
Apr 25, 2002 09:29 PM
