HonData System
Old May 4, 2003 | 08:28 PM
99turbosi's Avatar
Default HonData System
I have a 99 Civic Si, with a turbo on it, there are so many options that hondata offers, I was wondering what system and with what options I would need for my car? Also some recommendations on where to get the systems at a good price. Thanks.
JDEM1's Avatar
Default Re: HonData System (99turbosi)
basic hondata s200 with boost... best price PM member 2K_TEG
Old May 4, 2003 | 08:30 PM
ekb18c's Avatar
s100b will be fine and you can purchase it from me at a good deal. Comes with a starter map also. It really all depends if you are going to tune it yourself or not. If you are going to have it tuned by someone else then the s100b will be your best best. If however you want to play around with it yourself then s200b will be your best bet.
Old May 4, 2003 | 08:41 PM
99turbosi's Avatar
Default Re: HonData System (ekb18c)
Well, there is a company around my area that has the sofware to tune/adjust it, and a wideband so they were gonna do it on a dyno obviously, but there was not much I was going to do because for proper adjustment wouldn't you need a dyno? There really isn't anything I can change without a dyno is there?
I can't use that IM feature either so if u see this, email me(jmb45@pitt.edu) or IM me on AIM (jason5272) if you don't mind, I have some more questions and would like to check some prices ... Thanks.
Old May 4, 2003 | 08:44 PM
ekb18c's Avatar
Well, if you had a wideband 02 and a lamba meter then you could tune it on the street. However so i'm assuming you are just going to get it tuned and then forget about it, then your best bet would be to go get s100b. It's simple and it fits right into your stock ecu.
HTH.
Old May 4, 2003 | 09:45 PM
99turbosi's Avatar
Default Re: HonData System (JDEM1)
I'm not sure what PM member means? And does anyone know why I can only post 5 msgs a day and I can't instant message anyone?
Old May 4, 2003 | 09:49 PM
BOOSTED 4DR. GS-R's Avatar
I run the s200 it is great. I had a p72 ecu and it cost me 600.00 for system.
tunning extra......
Old May 4, 2003 | 09:54 PM
mskibbz-T's Avatar
Default Re: HonData System (BOOSTED 4DR. GS-R)
http://www.ks-motorsports.com if you click on the tech link in the upper right there is an article called Hondata 101, it explains the different options available and can point you in the right direction. You can PM 2K_TEG on here or call him at the number listed on the website
kreatekustomz
Dec 7, 2009 09:25 AM
Blindstuff
Jul 10, 2003 10:13 AM
int3gra
Jul 4, 2003 12:56 AM
messeduprex
11
Jun 21, 2003 06:13 PM
SiRkid
Aug 24, 2001 10:40 AM
