hondata s300 question?
Old Jul 15, 2008 | 03:32 PM
ef8_eg6's Avatar
Default hondata s300 question?
i run hondata s300..i had it on my old set up and ran well will getting tuned, i have a simlar set up on my new car, and for some reason, we been trying to tune it and it keeps disconnecting when we hit full throttle and wont let you data loggin.wat can it be..help would be great
Old Jul 16, 2008 | 09:51 AM
Spunkster's Avatar
Default Re: hondata s300 question? (ef8_eg6)
Most likely your ignition system....spark plugs must be resistor type, aftermarket ignition systems generate a huge amount of interference, plug wires may not be properly sheilded casuing huge amounts of interference, the cap itself may be aftermarket and be allowing interference.
Old Jul 17, 2008 | 12:21 PM
ef8_eg6's Avatar
Default Re: hondata s300 question? (Spunkster)
yeah that might be..i do run a msd set up, i run ngk bk7re which i was told are resister plugs..could it be a cold soter in the ecu
Old Jul 17, 2008 | 04:38 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef8_eg6 &raquo;</TD></TR><TR><TD CLASS="quote">yeah that might be..i do run a msd set up, i run ngk bk7re which i was told are resister plugs..could it be a cold soter in the ecu</TD></TR></TABLE>
Remove the msd box.
Old Jul 17, 2008 | 05:45 PM
miller's Avatar
Default Re: hondata s300 question? (mtber)
where is the msd mounted?
Old Jul 17, 2008 | 11:12 PM
uglyasscivic's Avatar
Default Re: hondata s300 question? (miller)
You can keep the msd. Move it away from the ecu if possible and rewire the coil leads with a shielded wire and ground the shields somewhere on the chassis. Run the coil lead away from the ecu and the engine harness.
Old Jul 18, 2008 | 02:09 AM
Turbo-charged's Avatar
Default Re: hondata s300 question? (uglyasscivic)
when i have this happen to me with customers cars on the dyno......99% of the time if you dont attempt to datalog during the pull......you can pull the intenal log with no problems.
having the ignition box mounted close to the ecu seems to always cause problems.
Old Jul 18, 2008 | 10:08 AM
ef8_eg6's Avatar
Default Re: hondata s300 question? (Turbo-charged)
the msd is mounted in the egine bay away from the ecu or harness..so is the coil..
Old Jul 18, 2008 | 10:20 AM
Spunkster's Avatar
If it is still connected to the car it will casue interference.
Old Jul 18, 2008 | 01:50 PM
ef8_eg6's Avatar
yeah i dont think i reall need it anyways..so im going to pull it off and see how it does
kilerintegra
Engine Management and Tuning
14
Nov 3, 2010 10:15 PM
adam1027
Feb 4, 2008 08:26 PM
ganjafarmer143
13
Oct 6, 2006 06:33 PM
jfoster
Nov 15, 2004 07:11 AM
pip9
Jul 28, 2004 05:06 AM
