hondata s200b question
Old Sep 7, 2004 | 07:30 PM
GReddy SI's Avatar
Default hondata s200b question
when i bought my hondata s200 with boost options
i was wondering when i install it do i have to retard timing
or does the stock base program retard timing already?
Old Sep 7, 2004 | 08:21 PM
Finest's Avatar
Default Re: hondata s200b question (GReddy SI)
Not necessairly. You have to set it to about 16 degrees base timing. Your tuner should do the rest with the ROMeditor program.
Old Sep 7, 2004 | 10:29 PM
Boofster's Avatar
Default Re: hondata s200b question (Finest)
I think the way it worked, we set the dizzy idle timing to as much retard as possible. Then you can change the timing per rpm from the software.
Same as the FPR.
Old Sep 8, 2004 | 01:25 AM
Dee's Avatar
Dee
Make sure the actual timing and the timing that you set in the software are the same. Check your timing with an accurate timing light and then make the necessary adjustments if the timing is not on the desired mark.
a1320honda
Engine Management and Tuning
May 16, 2013 06:19 AM
JDM97R
Sep 14, 2012 06:47 AM
brokenojoke
Jun 14, 2008 09:50 PM
brandond
Jan 16, 2005 07:21 PM
hybrid901
Sep 18, 2003 12:53 PM
