HONDATA problem? I disconnected the battery for 3 weeks now car wont idle.
The idle bounces back and forth from 1200 - 2000 continuously but only at idle, it drives fine though.
WTF? All I did was disconnect the battery for 3 weeks while i went on vacation. When i got back I changed some radiator hoses and heater hoses under IM and then an a/c line but thats all i did.
Does it have something to do with the hondata getting no power for so long? Does the hondata need to be reset or should i try to unplug it or something? I dont think it could be anything else. please help.
Re: HONDATA problem? I disconnected the battery for 3 weeks now car wont idle. (S03Burner)
you have air in the IACV when you changed out the hoses... you have air in coolant lines...turn heater to full blast HOT and start car... let engine run til fan turns on. fill up coolant. repeat til no more air in coolant lines
Re: HONDATA problem? I disconnected the battery for 3 weeks now car wont idle. (vteckiller)
problem fixed! I found a big vacuum line behind manifold was not plugged.
thanx for responses.
Modified by S03Burner at 4:22 PM 9/13/2003
Mud666
10-27-2005 01:05 PM
danny98r
01-02-2005 02:01 PM
