hondata problem help please
Old Mar 12, 2006 | 08:44 AM
civel's Avatar
Default hondata problem help please
ok.. i finished the rest of my turbo setup last night and pluged in my hondata. i got a base map for my stock b16 with 440's off a h-t member and had the chip burnt locally. so i installed the hondata and p28 with the jumper harness and my hondata red light is flashing, im not sure if that is right or not but the car runs the same with the hondata pluged in or not. it seems to me like there not connecting with eachother. any help would be really great. i need this car to get to work on monday.i have even tried another jumper harness. that wasnt the problem.
oh yea its hondata stage 2 with boost,p28 stock b16 dsm 440's, turbonetics t3
60 trim .48AR, 3" downpipe
thanks
Old Mar 12, 2006 | 09:54 AM
nsxmatt's Avatar
Most likely a bad burnt chip. Try to burn it again and see what happens.
Old Mar 12, 2006 | 03:45 PM
civel's Avatar
if the chip wasnt good wouldnt the car not start?
the car is running the same if the hondata is pluged in or not. ive searched on these forums and hondata forums.
someone help please
Old Mar 12, 2006 | 06:58 PM
88crxvtec's Avatar
Default Re: (civel)
hondata goes into safe mode if the chip isn't working, either the burn was bad, or the chip is plugged in wrong, check to see if the chip is in the right way and all the pins are in the socket, if thats ok reburn the chip.
Old Mar 16, 2006 | 03:20 PM
civel's Avatar
ok i had a new chip burnt the hondata is not connecting. thanks alot guys
TurboTeG4
Aug 4, 2005 03:01 AM
dnatrance
Mar 23, 2005 01:57 PM
h22ame
Mar 27, 2004 03:41 PM
speedyonez
Oct 20, 2003 06:49 PM
