hondata problem..
Old Apr 22, 2004 | 09:08 AM
spoon23_JDizM AkA SpOoN20's Avatar
Default hondata problem..
cars starts fine with reg stock ecu,and once i put the ls chipped hondata s200 in the car wont start at all?
Old Apr 22, 2004 | 09:19 AM
PM-Performance's Avatar
Default Re: hondata problem.. (spoon20)
try and reburn the rom , sometimes they dont burn on the 1st shot . also make sure the chip is in the correct direction.
Old Apr 22, 2004 | 10:07 AM
Default Re: hondata problem.. (itr206)
anyone else with this problem
Old Apr 22, 2004 | 10:31 AM
V-SPEC 1's Avatar
check the 4 wire that goes inside your ecu, make sure it connected right.
Old Apr 22, 2004 | 11:27 AM
Hoosier Daddy's Avatar
Default Re: hondata problem.. (boostedb20vtec)
Might be going out on a limb, but you're not using the chip that it came with the way it came, are you?
Old Apr 22, 2004 | 11:29 AM
ladysman's Avatar
Default Re: hondata problem.. (Hoosier Daddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy &raquo;</TD></TR><TR><TD CLASS="quote">Might be going out on a limb, but you're not using the chip that it came with the way it came, are you?</TD></TR></TABLE>
My initial thought as well.
Old Apr 22, 2004 | 02:52 PM
Default Re: hondata problem.. (ladysman)
well its was off a stock ls turbo,is that a bad thing?or would my hondata tuner have to change it?
Old Apr 22, 2004 | 03:42 PM
grndcont's Avatar
well, do you drive a stock ls turbo aswell?
Old Apr 22, 2004 | 07:02 PM
Default Re: (grndcont)
yes sir i do
Old Apr 23, 2004 | 06:34 AM
Default Re: (spoon20)
Old Apr 23, 2004 | 06:57 AM
J337_UNIT's Avatar
car should start without the chip anyway..but in limp mode
Old Apr 23, 2004 | 02:57 PM
Spunkster's Avatar
Is your car OBD2? Are you usign a Hondata modified P28 with a built in adapter harness? If so, you may be trying to use a OBD2a ecu on an OBD2b car or vice versa.
Modified by Spunkster at 6:49 PM 4/25/2004
shyboi4u
May 11, 2006 09:53 PM
lemongreenhatch
Aug 21, 2004 04:46 AM
NiceDc2r
May 19, 2004 07:52 PM
glagola1
Aug 22, 2003 08:51 PM
92HB_HB
Feb 17, 2003 10:05 PM
