Hondata need help!
Old May 21, 2002 | 08:50 PM
ichibanjap's Avatar
Default Hondata need help!
I am thinking about buying a hondata from a friend of mine. My question is will it help my setup and how complicated is it to use. I have an H22 with a turbo, and plan on building the motor later. I just looked at the Hondata website and it looks a little confusing to use. Also my friend had a p28 ecu with his setup, do I need the p72 for the H22 so I can get the knock sensor and the IAC to work or is it not necessary. I can get it pretty cheap so if it's no use right now then would it be any use later. Thanks for any info
Old May 21, 2002 | 08:53 PM
RH+G's Avatar
Default Re: Hondata need help! (ichibanjap)
The Knock sensor is useless. The IAC will work with either one.
Old May 21, 2002 | 08:58 PM
ichibanjap's Avatar
Default Re: Hondata need help! (RH+G)
Thanks do you know if it's a pain in the *** to use.
Old May 21, 2002 | 09:04 PM
RH+G's Avatar
It should be plug and play. WHat year motor do you have?
Old May 21, 2002 | 09:05 PM
ichibanjap's Avatar
The motor is a 95. I just was worried about the endnote on the Hondata page for the accord and the prelude. Just wanted a little more info about it.
Old May 21, 2002 | 09:21 PM
RH+G's Avatar
If I am not mistaken it says that the knock sensor is no longer working(no loss) and that it leaves the secondaries in the intake open. This gives you a small loss in low end power. Don't worry about either one. Get a ODB I Ecu and plug it up and go.
B Dap
Engine Management and Tuning
Nov 25, 2009 11:44 AM
pcguy760
May 17, 2005 11:26 AM
shreddinryguy
May 12, 2005 10:53 PM
B18Flip
Oct 28, 2002 05:53 PM
93B18
Feb 3, 2002 12:32 AM
