Hondata-- J12 what does it do
Old Mar 3, 2003 | 09:46 AM
BoostedH23a1's Avatar
Default Hondata-- J12 what does it do
well hondata tells u to cut jumper/resister J12 what does that actually do.. a friend of mine didnt cut his and it ran fine
Old Mar 3, 2003 | 09:59 AM
Doodoo's Avatar
Default Re: Hondata-- J12 what does it do (BoostedH23a1)
It allows the ECU the communicate better with the blue box when its removed.
You can tell when you datalog.
Old Mar 3, 2003 | 10:01 AM
Default Re: Hondata-- J12 what does it do (Doodoo)
will the ecu still run my friends car (b16) with that removed.. its a p72 ecu.. i just wanna make sure the ecu works
Old Mar 3, 2003 | 10:09 AM
Spunkster's Avatar
As long as you are using an s100 or s200 then you should leave j12 cut. If you use it on an older staged system then you will have to resolder j12.
95turbogsr
Jun 26, 2005 09:17 AM
iBrandon
Apr 18, 2005 08:01 PM
B16Civic93
Feb 17, 2005 08:54 AM
VtecInteg95
Jan 6, 2003 08:13 PM
