Hondata Intake Manifold Gasket! Problems!
Is there a procedure for installing these I should be aware of? I just installed one and it leaks air badly. I tightened all bolts, started it and it leaked. Tightened the bolts (which were then loose) and retightened. And again 2 more times. They just keep needing tightened. What is the deal? Thanks for the help.
Re: Hondata Intake Manifold Gasket! Problems! (iBrandon)
Tighten them from the inside out, if you start on one side and work your way over you'll have problems.
Honda_Fanatic
05-01-2007 11:42 AM
