Hondata Ignition Question
Old Jun 2, 2002 | 08:27 AM
PrecisionH23a's Avatar
Default Hondata Ignition Question
Yes... after searching 2 pages of threads and hondata.com i was not able to find the easy answer to my question. I have a crane hi-6tr ignition, if i run the hondata stage 4b will i still need it or does hondata take care of ALL your ignition needs? I know ill still need the GM 3bar map sensor. Also, to do my own tuning i will need the pocket programmer... correct? i plan on doing professional dyno tuning, but to get things started i would like to do a little bit of tuning in my garage to get it up and running, etc etc. thanks in advance...
Old Jun 2, 2002 | 09:00 AM
int3gra's Avatar
Default Re: Hondata Ignition Question (GudeH23a)
i asked sgt about this a while ago..........he said u still need an ignition system with hondata.....i forgot the detailed reason he gave
Old Jun 2, 2002 | 09:52 AM
dustin's Avatar
Default Re: Hondata Ignition Question (int3gra)
Hondata doesn't do any ignition amplification. It acts like the stock ecu and just tells the ignitor when to fire.
Old Jun 2, 2002 | 09:55 AM
Default Re: Hondata Ignition Question (dustin)
ahhh gotcha. thanks for the info, do you guys know if haltech needs an aftermarket ignition also?
Old Jun 2, 2002 | 10:00 AM
dustin's Avatar
Anything that doesn't come with its own ignition system would need an external ignition if you wanted one. (Tec2/3 come with distributorless ignition).
You can always use the stock ignition with them.
spAdam
Engine Management and Tuning
Oct 31, 2018 10:09 AM
delsol revolution
Jul 31, 2006 04:43 PM
boostedcivichatchbacksi
Jun 8, 2004 03:57 PM
redboost10
Oct 21, 2003 04:22 PM
FMXer
Jul 10, 2002 09:15 PM
