Hondata and IACV
Old May 22, 2004 | 08:08 PM
xrunner86x's Avatar
Default Hondata and IACV
Has anyone else had a problem with an OBDII idle air control valve working with a Hondata or other OBDI chip?
Old May 22, 2004 | 08:27 PM
Silverbeast's Avatar
Default Re: Hondata and IACV (xrunner86x)
Not a problem using hondata with an obd2 IACV. Is something wrong with your basemap, or did the tunerpossibily adjust it too much or too little?
Some information is needed to diagnose the problem better.
Old May 22, 2004 | 09:28 PM
xrunner86x's Avatar
Default Re: Hondata and IACV (Silverbeast)
Upon installation of the Hondata, idle became very choppy/rev happy, averaging 1500rpms and a vacuum of only 10 mmHg (not positive about units on that). The IACV was leaking vacuum, once the tuner unplugged it the idle became smoother, although still high and choppy, and the vacuum went to 20 at idle. They tell me I need to get an OBDI IACV and rewire it, since the OBDI IACV is 2 wire and the OBDII IACV is three wire, or something along those lines. I am using the Hondata in a 98 CL, which has the F23a1, and is not a listed application, however except for this problem, seems to work fine. Thanks for any additional info.
Old May 23, 2004 | 12:02 AM
Pfieff's Avatar
If stock you had a 3 wire IACV you will need to convert it over to a 2 wire IACV to work with the OBDI ecu. I had the same issues, took me forever to figure it out, but its an easy fix. Pick up a 2 wire IACV, pigtail for one and run one wire different on the harness.
Old May 23, 2004 | 02:52 PM
xrunner86x's Avatar
Default Re: (Pfieffdog)
Thanks, thats what they told me, but I wanted to makes sure it wasnt just my car and that there wasnt a simple solution.
Old May 23, 2004 | 03:22 PM
Smooth-GSR's Avatar
Default Re: (xrunner86x)
Hmmm, I am running a chipped obd1 ecu similiar to hondata or uberdata on my obd2 car and engine, its a 99 b18b Integra. I am recently having idling issues as well, but not all the time. Sometimes it can be hard to start the car and once started, the idle is lumpy and barely holds at about 250rpm before finally idling correctly at ~750rpm. Could this be my problem as well??
Old May 23, 2004 | 03:50 PM
xrunner86x's Avatar
Smooth, I'm not a turbo pro yet, but reading about the IACV it could just be dirty. If you do a google search there are cleaning instructions. It could also just be your tune reacting to different temperature and humidity conditions.
Old May 23, 2004 | 07:24 PM
si_azul's Avatar
weird, i have a 00 si with hondata and no idle problems (almost a year since the ecu change)
Old May 23, 2004 | 08:09 PM
xrunner86x's Avatar
Default Re: (si_azul)
The 00 Si is a listed application for Hondata. I guess they only list vehicles with no conversion issues because it obviously can be made to work in other vehicles.
BDogggUT34
Jun 8, 2007 08:38 AM
*Boostwerks*
Jun 6, 2005 01:39 PM
brokenojoke
Mar 23, 2005 07:51 AM
deez92
Oct 7, 2003 07:01 AM
Brian_92GSR
Feb 4, 2002 01:00 PM
