Hondata for automatic honda
Old Nov 14, 2005 | 03:56 PM
honda2213's Avatar
Default Hondata for automatic honda
Have anyone use hondata on an automatic car before? I never use hondata before and would like to know if anyone have use it before to give me some feedback. Does the car shift correctly?
Thanks.
Old Nov 16, 2005 | 09:19 AM
atcrx's Avatar
Default Re: Hondata for automatic honda (honda2213)
walt you can use a industrial plc to shift the trans. checkout http://web1.automationdirect.c...5DD-D
I am currently using a homemade shift controller. I will be using the one above next year. It should be able to use a tach input to make it shift at certain rpms for each shift. Right now the one I have only does 1 rpm for each shift. pm your number i would like to talk to you about some other auto trans stuff.
Old Nov 16, 2005 | 09:25 AM
beerbongskickass's Avatar
Default Re: Hondata for automatic honda (atcrx)
I would spend the money on a manual swap before wasting it on Hondata. Look into getting your ECU chipped with Uberdata/Crome which are free or spend a little on Neptune. I just can't justify spending the money on Hondata with all the other options.
Old Nov 16, 2005 | 09:52 AM
dornon13's Avatar
you cant use hondata s200 on an auto tranny im not sure if s300 can be but i would assume not.
Old Nov 16, 2005 | 10:43 AM
p0gi's Avatar
Default Re: Hondata for automatic honda (dornon13)
From doing research on it, the only hondata that was compatible with an auto was the 2b. I believe that neptune will work with an auto.
Old Nov 21, 2005 | 01:52 PM
honda2213's Avatar
Default Re: Hondata for automatic honda (p0gi)
Thank you for your input. I got the 2b hondata already. I just want to know if someone already had use it on their automatic car. I contact Hondata and they told me that most of the old Hondata stage system will work with automatic but not the new S series (S100, etc.). I guess I just have to try it out and see how that go.
haveaNOSday
Nov 23, 2005 08:03 AM
22boost
Nov 11, 2004 01:29 PM
GreddySi99
Sep 27, 2003 05:39 PM
