Which Holset would suit me best
Hey guys,
Which Holset turbo would suit me best out of the the HX30W, HX35W, HY30W & HY35W ?
The car is a stock b16 with CTR cams and is mainly street driven with the odd track/drag strip day. I would
like as fast spool as possible with power upto 8500 rpm. My power goal would be from 350HP to 400hp.
Thank you for your time
Re: Which Holset would suit me best
I know you can get the HY35 in a 9cm exhaust housing. Either way you go, those should hit your power goals. The more these turbos flow the more efficient they get. Just make sure to get a smaller 9cm turbine housing if you're looking for a quicker spool up time.
