hmmmm....change the stroke on the motor?
Old Jun 1, 2002 | 12:44 PM
SiRkid's Avatar
Default hmmmm....change the stroke on the motor?
i was thinking....well a friend and I were. How about you take a b16 motor. .. then take a b20 crank and put her in. with custom rods and some pistons and youd have a 2.0L would you not? the rod ratio would be **** and you could only rev to like 6500 rpm but there would be crazy *** torque and it would be fun. hmmmm.
just a thought. I wouldnt do it to my car. THis would maybe be a little something on the side.
Old Jun 1, 2002 | 02:03 PM
Cramerox's Avatar
Default Re: hmmmm....change the stroke on the motor? (SiRkid)
sounds like a good i dea...if you got a b20 crank and b16 block why not....
Old Jun 1, 2002 | 06:11 PM
MoBlack's Avatar
New User
Default Re: hmmmm....change the stroke on the motor? (Cramerox)
I'm not sure on this, but I think just dropping the b20 crank in a b16 will more closely yield 1.8liters. You'd have to shorten the rods quite a bit to make 2.0liters. This would throw off the geometry waaaaay too much...
I don't think it's a good idea.
If I'm wrong someone please educate.
Old Jun 2, 2002 | 11:53 AM
SiRkid's Avatar
Default Re: hmmmm....change the stroke on the motor? (MoBlack)
i think it will work! like i said...the ratio will be total ***** and you can only rev to like 6 grand...basically it will be NON honda like.....aahahhaa...
i dunno,,,,maybe if i get some spare cash and have nohting to do withmyself.
Old Jun 2, 2002 | 12:00 PM
int3gra's Avatar
where can i read up on changing strokes (is it in Maximum Boost)?
i was thinking of knife-edging my b18b.......but if a b20 is better maybe i can do it to that. i need some reading sources
Old Jun 2, 2002 | 01:21 PM
DLB1994's Avatar
Default Re: hmmmm....change the stroke on the motor? (int3gra)
b18b and b20 has the same stroke the crank is the same
Old Jun 2, 2002 | 02:14 PM
Total Eclipse RS's Avatar
You'd be a million times better off just using a B20 block.......what would the point be of using the B16 block? Im missing something.
[Modified by Total Eclipse RS, 3:14 PM 6/2/2002]
Old Jun 2, 2002 | 02:26 PM
SiRkid's Avatar
Default Re: hmmmm....change the stroke on the motor? (Total Eclipse RS)
i dunno.just to do something different...you could be like..yup..1.6 L and really have 2.0 ...ahaha.i dunno.i t was just a thought.im not doing it to my car.
Old Jun 2, 2002 | 02:29 PM
SiRkid's Avatar
Default Re: hmmmm....change the stroke on the motor? (DLB1994)
actually.hes right...hmmm....but woudl it not still be 2.0 L????
Old Jun 2, 2002 | 03:05 PM
DLB1994's Avatar
bore it around 84-86mm with the with the b18B crank u may get somthing like around the high 1.8'cc's or low 1.9cc's
that honda kid
23
Mar 22, 2010 07:17 AM
myblackhatch
Jul 17, 2006 02:41 PM
Dr Honda
Nov 14, 2003 03:23 PM
88 rex
Mar 13, 2003 07:29 PM
FreeMyndz v.FP
Jan 14, 2002 04:05 AM
