HKS SSQV Flutters
Old Oct 30, 2006 | 05:17 PM
jsoob's Avatar
Default HKS SSQV Flutters (edit: with video of problem)
The bov been fluttering since I got it, I'm pretty sure this isn't the sound it is supposed to make. From what i've been told it's supposed to have a high pitched chirp. Any ideas as to why it's doing this? Here is a picture if it helps:
Modified by jsoob at 9:29 AM 10/31/2006
Old Oct 30, 2006 | 05:25 PM
BoostedGreddy's Avatar
its supposed to flutter once and a while at low rpms/boost
Old Oct 30, 2006 | 05:31 PM
jsoob's Avatar
It does it all the t ime even at 6 psi high or low rpm.
Old Oct 30, 2006 | 05:42 PM
ccivic's Avatar
Default Re: (jsoob)
Could be because it's only 6psi. Why not use a real HKS flange instead of that ghetto rigged thing? -afraid of boost leaks-
Old Oct 30, 2006 | 05:45 PM
Bboy_Trevstuh817's Avatar
Is that a knock off ssqv that could be why it flutters!
Old Oct 30, 2006 | 05:49 PM
b18sihatch's Avatar
Default Re: HKS SSQV Flutters (jsoob)
FIX THAT FLANGE
jsoob's Avatar
No it's a real ssqv. Could it be a compression surge?
Old Oct 30, 2006 | 05:53 PM
Mr HYDE's Avatar
Default Re: (jsoob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsoob &raquo;</TD></TR><TR><TD CLASS="quote">No it's a real ssqv. Could it be a compression surge?</TD></TR></TABLE>
if its loud flutter then most likely it is. maybe ur bov isnt even opening, check vacuum source and fix that flange
Old Oct 30, 2006 | 07:06 PM
moores55's Avatar
Default Re: (Mr. HYDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. HYDE &raquo;</TD></TR><TR><TD CLASS="quote">
if its loud flutter then most likely it is. maybe ur bov isnt even opening, check vacuum source and fix that flange</TD></TR></TABLE>
he is right. I had the HKS bov and when i first installed the turbo kit i ran the bov from the fpr. well all i could here was fluttering, so i put a vacuum T at the brake booster an ran it from there and it fixed the problem. Your not getting enough vacuum. btw i only ran 7psi and it sounds good.
Old Oct 30, 2006 | 07:27 PM
jsoob's Avatar
Thanks guys I really appreciate this, I'll change the vacuum lines tomorrow and let you know how it goes. It seems that a lot of people have the same problem so if I get it to work then this is the easy fix.
Old Oct 30, 2006 | 08:28 PM
F20Cteg's Avatar
Default Re: (jsoob)
Unscrew the bolt in the back almost all the way out.
The great design of the SSQV allows you to run a very very soft spring without it leaking.
Old Oct 30, 2006 | 09:11 PM
BoOsTeD C1's Avatar
Default Re: (Bboy_Trevstuh817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bboy_Trevstuh817 &raquo;</TD></TR><TR><TD CLASS="quote">Is that a knock off ssqv that could be why it flutters!</TD></TR></TABLE>
even the fake ssqv sounds like the real one....His fluttering is probably just the bov needs adjustment and damn the flange is ghetto rig
Old Oct 30, 2006 | 09:58 PM
Attaus's Avatar
There's generally an adjustment screw. Right now it's on soft.
Compressor surge is more of a chop than a flutter.
Old Oct 30, 2006 | 10:04 PM
under_psi's Avatar
Default Re: (Attaus)
my ssqv fluttered until I ran a vac source direct from the intake mani without anything else T'd off of it. now it only flutters at partial throtle while barely boosting. the response of the ssqv sucks though, big time. I regret getting it. just because it's "HKS" doesn't mean it's any good.
Old Oct 30, 2006 | 10:11 PM
turbotime's Avatar
switch your vac source to T off the brake booster.
Old Oct 31, 2006 | 04:45 AM
drunkinmaster1's Avatar
i have an ssqv and it flutters at lower boost level like 6 psi. at 20 psi it sounds like a pissed off bird from hell, very loud chirp. i also know other with the same boost levels and the flutter is exactly the same at lower boost levels. the valve has 2 blow off levels. one for high boost, one for low. thats why its called "Super SEQUENTIAL Blowoff''.
im sure if you raise your boost levels a bit youll get the chirp from the higher stage level.
Old Oct 31, 2006 | 06:37 AM
Drkaccrd's Avatar
Default Re: (under_psi)
ummm yeah perhaps the line is pinched to the bov ive had that happen to me, it does flutter all the time check that before you make that asumption. I've owned an HKS bov for years and its always sounded good. Its just you thats all.
Old Oct 31, 2006 | 06:42 AM
Muckman's Avatar
Moderator in Chief
are you using the plastic check valve filter thing inline with the vac tube? you probably have that backwards.
Old Oct 31, 2006 | 06:50 AM
turbotime's Avatar
Default Re: HKS SSQV Flutters (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">are you using the plastic check valve filter thing inline with the vac tube? you probably have that backwards.</TD></TR></TABLE>
i didnt even use that. OP if you have that i would jsut remove it its useless
Old Oct 31, 2006 | 08:13 AM
jsoob's Avatar
I have a video of my car on the dyno @ 4 psi and the sound it makes is very clear in there cuz the guy dyno'ng it gives it a hard pull. Check it out for me please and let me know what you think it is.
Here's the link:
http://s109.photobucket.com/al...o.flv
Old Oct 31, 2006 | 09:21 AM
F20Cteg's Avatar
Default Re: (jsoob)
The BOV is not opening or not opening far enough.
Try changing the vac source and unscrewing the adjustment bolt in the back.
Old Oct 31, 2006 | 09:56 AM
jsoob's Avatar
I've been told to change it to the brake booster, I'm not 100% sure where that is. Can anyone find me a pic or tell me where it is? Also how easy is it to hook it up to it.
Old Oct 31, 2006 | 11:09 AM
cua0's Avatar
brake booster is that big black round thing that the master cylinder is mounted to, follow your hydraulic clutch lines to it or follow your brake lines to it. it will be directly opposite the firewall of your steering wheel usually.
Old Oct 31, 2006 | 11:26 AM
AllAboutTheB's Avatar
Default Re: (cua0)
Mine fluttered as well. Then I switched it to a dedicated port off my intake mani and now it doenst flutter at all, just the high pitched sound ( chimpmonk ) as my friends call it Isnt that right Jeff? That should take care of the problem... unless its your flange.
Old Oct 31, 2006 | 12:38 PM
adictionbass's Avatar
Default Re: (AllAboutTheB)
if the flange isnt leaking, then that shouldnt be a problem at all.
