hitting rev limiter with a turbo - is it bad for your engine?
Old Nov 20, 2001 | 04:21 AM
ben_vtec's Avatar
New User
Default hitting rev limiter with a turbo - is it bad for your engine?
is hitting the rev limiter bad when you have a turbo'd honda. i heard it was bad to hit it when using nitrous. and know that some turbo cars i have driven cut out for a second or so (escort rs turbo) where others have a conventonal rev limiter (pulsar gtir). does it cut out for a reason or is it just a different type of limiter.
i dont plan on bouncing my car off the limiter every time i pull out of a junction......i just want to know if i should be extra careful to avoid doing it.
can i rev it as high anyway with a turbo (b16a2)
cheers
Old Nov 20, 2001 | 04:28 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: hitting rev limiter with a turbo - is it bad for your engine? (ben_vtec)
Factory limiter (fuel cut) is the worst thing you can do on a boosted or juiced motor. The best idea is to get ECU rechipped and use a MSD 6AL to cut spark before the fuel cut kicks in. A fuel cut is the worst form of lean out possible!
FYI I have a D16Z6 on juice. I'm using a Locash ECU with a 8500 fuel cut. My MSD 6 AL is set at 7600 or 7800 rpm.
Old Nov 20, 2001 | 04:50 AM
meanteg's Avatar
New User
Default Re: hitting rev limiter with a turbo - is it bad for your engine? (Mista Bone)
Yes, it can damage your engine if you hit it too often.
btw, Can someone confirm me that on a 94-01 Teg GSR the cutoff is an ignition cut ?
Old Nov 20, 2001 | 04:58 AM
immortal's Avatar
Banned
Default Re: hitting rev limiter with a turbo - is it bad for your engine? (meanteg)
all stock cuts are fuel cuts
Old Nov 20, 2001 | 06:09 AM
RGAZ's Avatar
New User
I am with bone. NEVER hit a stock rev limit (fuel cut) while boosting. It is the worst form of lean-out possible and will make very high cylinder temps. Get a MSD 6AL soft-touch and you can hit it all day.
Randy
Old Nov 20, 2001 | 06:16 AM
civicgsr's Avatar
Default Re: hitting rev limiter with a turbo - is it bad for your engine? (RGAZ)
I'll agree with everyone on the rev limiter issue. Another form of protection, is setup a shift light and have it flash before you get to redline. Maybe 500-700 rpms early. Hondata's is setup to flash at 7800 with an 8500 redline.
The best form of protection is an aftermarket ignition with rev control. It even feels better than the fuel shutoff.
-Alex
Old Nov 20, 2001 | 08:06 AM
bruthaboost's Avatar
Default Re: hitting rev limiter with a turbo - is it bad for your engine? (civicgsr)
This may be a stupid q, but how can one go lean with a fuel cut. If the fuel is cut, isn't there nothing to ignite-isn't just hot (compressed) air? So doesn't the engine essentially just pump air for the brief moments (while the tranny/internal resistance is slowing it down) it's above the limiter.
Old Nov 20, 2001 | 08:11 AM
civicgsr's Avatar
Default Re: hitting rev limiter with a turbo - is it bad for your engine? (b18bpwr)
I'm going to venture to say that there will always be a little unburnt fuel in the cylinder but it is possible that there would so little fuel that if it did detonate, it wouldn't be significant enough to cause a problem.
My thought, so if it's totally off base, I apologize.
-Alex
Old Nov 20, 2001 | 09:26 AM
RGAZ's Avatar
New User
There is always a little fuel being sucked into the engine because not all is burnt every cycle and the cylinder isn't totally cleared every cycle. So what that means is you get a very hot burn for a cycle or two which heat-soak the valves and can damage them faster than they can disipate the heat. This is especially bad at high rpms when the firing cylces are very close together and the car is under a heavy load. The key to the whole idea is that the temperature of the combustion is too high for the chamber to properly dissipate the heat and things start to melt. Its just plain bad.
Randy
Old Nov 20, 2001 | 10:43 AM
TypeC's Avatar
I know this is true for Nitrous, but I never heard of it about boost. I've bounced off the rev limiter at 16psi in my WRX plenty of times (not intentionally, but in a drift) and nothing happens. I haven't watched my EGT's at the time, but no one's said anything about it being a concern (of course you can't be a dumbass).
Old Nov 21, 2001 | 03:40 AM
ben_vtec's Avatar
New User
what type of rev limiters does a hondata use?
Old Nov 21, 2001 | 05:12 AM
civicgsr's Avatar
It's a fuel cut rev limit. They are using the stock method of rev limit. I think it would be far more difficult to reprogram the ECU to incorporate ignition cut.
Or, may monkies fly out of my ***....
Old Nov 21, 2001 | 04:30 PM
ben_vtec's Avatar
New User
so what about the full throttle shifting which hondata say doubles as anti-lag on a turbo'd car.......and the rev limiter for keeping you at constant revs for your launch
Old Nov 21, 2001 | 04:41 PM
SIK IN DA HED's Avatar
New User
Default Re: hitting rev limiter with a turbo - is it bad for your engine? (TypeC)
your car doesnt count... it already came turbo'd. hehe im sure the engineers prepped the ecu to avoid problems like that. if not... then oh well!
Old Nov 21, 2001 | 04:42 PM
New User
i wonder if it hurts your engine if you misshift and tach it over redline by accident.
hondacummins
Engine Management and Tuning
12
Jul 20, 2014 08:14 PM
htludernewbie
Aug 25, 2002 03:06 AM
90EF8si
May 12, 2002 06:06 PM
LshatchTurbo
Jan 15, 2002 06:06 AM
Black R
Jul 25, 2001 12:46 PM
