High-power engines: ignition?
Old Aug 17, 2005 | 09:55 PM
  #26
Tony the Tiger's Avatar
Default Re: (b18ccivics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ccivics &raquo;</TD></TR><TR><TD CLASS="quote">i am currently running AEM ems 30-1000 with the AEM cdi and four MSD blaster ss coils wasted spark on my turbo charged b18c1 and love it
That looks sick....
How did you manage to drive those Blaster coils? Did you have a CDI unit, or did those coils have an ignitor built-in? Can you elaborate? I am trying to have a good ignition system WITHOUT the need of a CDI boxe because no company out there makes a decent one with a competitive price.
Old Aug 17, 2005 | 10:03 PM
  #27
agturbo's Avatar
Default Re: High-power engines: ignition? (BlackPhoenix)
im running a 7AL - 2 with a pro power HVC coil, no problems yet..
Old Aug 17, 2005 | 10:11 PM
  #28
D-tuned's Avatar
Default Re: High-power engines: ignition? (agturbo)
I'm running the AEM C2DI(4 channel) with 4 honda 954 coils sticks in a direct fire configuration
Old Aug 18, 2005 | 05:41 AM
  #29
Phoenix1's Avatar
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">im going to be using an aem 1000 box with the dis 4 using a coil on plug setup and share the same concern with unit failure.
also with the dis 4, does it use a 12v + to trigger the coil or does it ground out the coil to trigger it?</TD></TR></TABLE>
The DIS-4 uses ground to trigger the coils. All MSD DIS Series use this method. Everything else uses the opposite, a 12 volt + fires the coil.
Old Aug 18, 2005 | 05:45 AM
  #30
Phoenix1's Avatar
Default Re: (Tony the Tiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">I appreciate the great tech support of MSD, but again, time is money and each time I send something back to MSD, I am looking at a month downtime with shipping things back and forth across the border (from Canada to US).
It would be great if we can find out the cause of the failure other than being in the dark </TD></TR></TABLE>
I can certainly understand your frustration. I'm working on finding out the failures of this box. It seems to be a pretty popular box when converting to individual coils, and works well. I'll get back to you guys on that one.
Old Aug 18, 2005 | 05:53 AM
  #31
wantboost's Avatar
Who is Mr Robot?
Default Re: (BlackPhoenix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackPhoenix &raquo;</TD></TR><TR><TD CLASS="quote">
The DIS-4 uses ground to trigger the coils. All MSD DIS Series use this method. Everything else uses the opposite, a 12 volt + fires the coil.</TD></TR></TABLE>
ok cool, because with building race bikes, all of our systems trigger the stock coil using the ground which prefer, gives a more accurate signal imo. not to mention ive got a bitching custom made 6 led shift light that prefers to use the ground type trigger
Old Aug 18, 2005 | 05:54 AM
  #32
tuoniz's Avatar
cush!
Old Aug 18, 2005 | 06:16 AM
  #33
93H22ACX's Avatar
Default Re: (jerseykid609)
H22= 6AL with blaster ss
GSR=Digital 6 and HVC II coil
Old Aug 18, 2005 | 08:39 AM
  #34
Phoenix1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 &raquo;</TD></TR><TR><TD CLASS="quote">I run a 6al box 3 step, msd cap with HVCII coil (meant for the 6 series) and its worked out great..
My biggest problem with msd is there plug wires for B series engines. They like to pop off the spark plug way too often they should fix that they sell way more plugs.
I know i hated after every pass i could almost guarantee that at least one plug popped off the spark plug. </TD></TR></TABLE>
Are your wires a custom set that you assembled yourself?
Old Aug 18, 2005 | 08:50 AM
  #35
Boostfed's Avatar
New User
Are your wires a custom set that you assembled yourself?</TD></TR></TABLE>
No they arent, they are the ones made for his engine. All aftermarket plug wires do this even my old Magnecore 10mm wires, we just wire tie them, But
I use straight stock wires now anyways.....ooops I went to COP
Old Aug 18, 2005 | 09:34 AM
  #36
Dunc's Avatar
BCICAN
they fall off on both ends dizzy and plug, but if u zip tie them to the dizzy they really dont give you any troulble on that end. on the plug side they just pop off the spark plug so u have to snap them back on.. every run it seems. </TD></TR></TABLE>
That's good to know, at least I am not the only one with superconductors popping off the dizzy. It's weird, you would think they stick on there pretty snug to prevent that or something.
Old Aug 18, 2005 | 09:47 AM
  #37
JDM_Risa's Avatar
Default Re: (Dunc)
i will soon be upgrading my ignition system too...msd digi 6, 8.5 wires, 2 step colder ngk, and cap and SS external coil blaster my car is miss firing so bad that i can't even do a clean pull on the dyno
Old Aug 18, 2005 | 09:58 AM
  #38
tony1's Avatar
Default Re: (Black_JDM Type R)
Chuck Seitsinger ran an 8.37 @ 173 in the finals at the last event. He came back and said it must have hit a boost cut or something cause it was popping all through fourth. I looked at the datalog and everything looked great. When i went to pull the plugs out to check them, i noticed the #3 plug wire had popped off! lol It was kinda good news to us though, cause we know it has more in it!
On a side note, that car used to have a digital 7 ign on it and we had to change plugs all the time or it would misfire at high boost. Chuck finally gave in and got a motec cdi ignition. Never once had a problem again. About halfway through this year I noticed his plugs were starting to rust and i asked him how long he's been running them. He kinda got an odd look on his face and thought about it for a min. He said, they're the ones you put in a year ago when you did the ign., they've never given me a problem so i never changed them! lol That was almost a full year of racing on 1 set of plugs, running well over 45psi, sometimes upwards of 60psi!
Old Aug 18, 2005 | 10:48 AM
  #39
choiboiracing's Avatar
Default Re: (tony1)
damn tony, its like that ehhhh... i told the birthday fairy that i wanted the motec cdi. i was thinking about it, what if my motor doesnt start????
Old Aug 18, 2005 | 10:53 AM
  #40
Phoenix1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 &raquo;</TD></TR><TR><TD CLASS="quote">they fall off on both ends dizzy and plug, but if u zip tie them to the dizzy they really dont give you any troulble on that end.</TD></TR></TABLE>
These will help cure that problem when they come out:
http://www.msdignition.com/sci_8.htm
Not 100% sure of their release date yet...
Old Aug 18, 2005 | 10:55 AM
  #41
DaveF's Avatar
blackphoniex.
can you tell me what the delay is with the honda distributer? we've been trying to get one for a long time now.
Old Aug 18, 2005 | 11:41 AM
  #42
Phoenix1's Avatar
Default Re: (Dturbocivic)
Can't tell you the reason, but patience is a virtue...they're coming out very soon, now.
Old Aug 18, 2005 | 11:45 AM
  #43
Dunc's Avatar
BCICAN
I heard somewhere (can't remember where), but there can be so much blowby pressure in the cylinders that it goes around the piston rings then actually around the spark plus seals and pops the spark plug wire off. We had this problem on a car in the shop so we took a tiny drill bit (1/16") and made a small hole in the black rubber cap covering the hole.
Old Aug 18, 2005 | 12:03 PM
  #44
tony1's Avatar
Default Re: (Dunc)
I took some wire cutters and cut out a little pizza shape in the boot on the motor so that wouldn't happen. Thing is, i did that over a year ago, still happened! lol The heat and vibration just starts to take a toll on things and loosen things up.
Old Aug 18, 2005 | 12:23 PM
  #45
Flr Power's Avatar
Default Re: (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">I heard somewhere (can't remember where), but there can be so much blowby pressure in the cylinders that it goes around the piston rings then actually around the spark plus seals and pops the spark plug wire off. We had this problem on a car in the shop so we took a tiny drill bit (1/16") and made a small hole in the black rubber cap covering the hole.</TD></TR></TABLE>
That's impossible. The blowby would not come back at the spark plugs since the spark plug is airtight.
Old Aug 18, 2005 | 12:26 PM
  #46
tony1's Avatar
Default Re: (Flr Power)
Actually, with 2000+psi in the cylinder, you'd be surprised...
Old Aug 18, 2005 | 12:59 PM
  #47
Dunc's Avatar
BCICAN
I don't know how possible it is...but I remember reading about it from a pretty reliable source (one that wouldn't just say **** to say it). It was from a company I think? I really can't remember.
Old Aug 18, 2005 | 01:01 PM
  #48
.dave's Avatar
i HAS questions ?
Default Re: (tony1)
I could picture that with insane crankcase pressure and shitty seals from the valvecover to spark plug tube (whatever you want to call it). Back when my head was screwed up the crankcase would build up so much pressure that it would pop the dipstick out and if you started to unthread the oil cap it'd shoot up about 10 inches off the valvecover at idle.
Old Aug 18, 2005 | 10:04 PM
  #49
b18ccivics's Avatar
That looks sick....
How did you manage to drive those Blaster coils? Did you have a CDI unit, or did those coils have an ignitor built-in? Can you elaborate? I am trying to have a good ignition system WITHOUT the need of a CDI boxe because no company out there makes a decent one with a competitive price.</TD></TR></TABLE>
the coils do not have a built-in ignitor i am using AEM ems and AEM cd2i. I have a post of my complete setup at http://forum.aempower.com/bbs/...light=
Old Aug 19, 2005 | 11:25 AM
  #50
SpoolinDa's Avatar
I know of several 600 hp cars with stock honda ignitions. just different pugs, either 7 or 9s
