High Miles
Old Feb 9, 2005 | 12:55 PM
Kawaii's Avatar
Default High Miles
After reading the FAQ, I feel confident that this isn't a common ?. My motor just hit 100K. Is it still safe to add FI?
Old Feb 9, 2005 | 03:05 PM
cnydc2's Avatar
Default Re: High Miles (Kawaii)
You should be fine. Do a comp test and if everything checks out then throw 7-8psi at it and you shouldn't have any problems. Just be sure that you have it properly tuned.
Old Feb 9, 2005 | 03:16 PM
adseguy's Avatar
Default Re: High Miles (cnydc2)
use the search button as well and try differnt keywords like mileage, high mileage, 100k+, and things like that that or leak down, compression test. You will learn a lot that way.
As cnydc2 said if the numbers check out on those tests you may boost away and keep a good tune
Old Feb 9, 2005 | 03:18 PM
93turbo16's Avatar
128,000 + and still running stong on my sohc vtec.
Old Feb 9, 2005 | 05:13 PM
Kawaii's Avatar
Default Re: (93turbo16)
Awesome guys, thanks for the info. I'm going to do those searches you talked about, Adseguy. I will surely ask another ? if I don't find it in those searches. Once again, HT pulls through with the answers.
Old Feb 10, 2005 | 06:22 AM
Kawaii's Avatar
Default Re: (Kawaii)
Found a thread stating that my engine should have a compression test of 200 so I'm going to check that out asap.
Y0N1P8T5R1F5A4T
Honda S2000
26
Nov 2, 2009 02:15 AM
blackeg
Jan 5, 2009 04:51 PM
psycheus
Oct 21, 2004 02:44 PM
InLimbo87
Jun 22, 2004 07:54 PM
hondaracing1
10
Feb 8, 2004 07:32 AM
