High/Low Boost with AC switch with S300?
Old Mar 27, 2009 | 04:46 AM
chad's Avatar
Moderator
Default High/Low Boost with AC switch with S300?
Well, Anyone have the schematics to do this with the s300?
Old Mar 27, 2009 | 07:09 AM
HiProfile's Avatar
Default Re: High/Low Boost with AC switch with S300?
I'm pretty sure the ectune.com forum has a thread that explains it for non-AC cars. Unfortunately I'm in a hurry so I can't look just yet.
If it started as an AC-equiped car, you'll just get the ebc feature, then hit the button.
Old Mar 27, 2009 | 09:08 AM
TimKennard's Avatar
on OBD1 ecu's, B5 is the ac input if you do not have AC and need to wire it in. B5 to ground activates it. the rest is software settings.
Old Mar 27, 2009 | 09:15 AM
93turbo16's Avatar
All you do is run one side of the switch to ground and the other side to pin B5.. like stated above.
In the software you should see the AC input be activated when you flick the switch and it will switch to your high boost anytime the AC switch is grounded.
Old Mar 27, 2009 | 04:05 PM
Redcoupe's Avatar
Learn something new everyday. Thanks fellas.
Old Mar 27, 2009 | 06:38 PM
boostedcivicsir's Avatar
Mr. Badwrench
should say anytime b5 is grounded.
Old Mar 27, 2009 | 06:59 PM
93turbo16's Avatar
Eh. If you want to get technical about it.. yea.
gabrielsousa
Engine Management and Tuning
Nov 10, 2014 01:00 PM
afnan
Mar 4, 2014 11:30 PM
TehGhett0P1mp
Jan 7, 2009 09:34 PM
StupidSlowRSX
Sep 3, 2007 02:28 PM
SOHC_MShue
Aug 19, 2004 08:37 PM
