High-HP guys...engine/tranny stiffeners? searched..
I have been searching and searching to no avail...what are everyone's thoughts on the tranny-to-engine stiffeners? Anyone with high HP and drag strip passes, etc have any insight?
I have one bolt hole stripped and another not doing so good, and I really just dont want to run them. It appears that with some scattershields that they CANT be run anyways, so Im assuming plenty of high-HP cars run without them?
I havent been able to really find any input, only from one reputable source, but Id like to get everyones input before I make a decision...thanks in advance!
Re: High-HP guys...engine/tranny stiffeners? searched..
tranny to engine stiffeners? take a picture to define what it is your talking about more thoroughly please
I believe he is talking about the L-shaped aluminum brackets that bolt between the lower section of the bell housing and the bottom side of the block. The B-series engines have 2, and the ITR has that whole sheild assembly.
Yeah, thats what Im talking about. The two OEM brackets.
not sure what your definition of high HP is...but i track 11.9's i run them both... If the OEM designed the motor around it, its likely there for a purpose wether we know what that is or not...but if for some reason you dont run them on your car I wouldnt go nuts over fixing it...
I am assume its function is to keep the "unsupported" bottom half of the tranny stable and keep from flex and whatnot. But I want some input from the high-HP guys to confirm that they really are not necessary. I just dont want to go nuts trying to get them on when I am fine without. I do find them rather annoying...lol
alscrx
Transmission & Drivetrain
12
10-20-2009 03:56 PM
b18c, bellhousing, civic, engine, gsr, honda, series, stiffener, stiffeners, stripped, tech, tranny, transmission
