High Flow Fuel Pump Question
Old Dec 30, 2001 | 07:09 PM
slowcivic's Avatar
New User
Default High Flow Fuel Pump Question
What are people's recommendations for a high flow fuel pump that supports 400 to 450 whp. Its a turbo setup with a B18C1 engine and Speedpro bank to bank engine management. Thanks.
Old Dec 30, 2001 | 07:18 PM
TurboITR's Avatar
Default Re: High Flow Fuel Pump Question (slowcivic)
aeromotive 1000hp pump...
(its a bit loud though)
Old Dec 31, 2001 | 06:41 AM
slowcivic's Avatar
New User
Default Re: High Flow Fuel Pump Question (TurboITR)
Thank you TurboITR! Does anyone else have any suggestions? Thank for any info.
Old Dec 31, 2001 | 08:02 AM
rtype11's Avatar
I suggest you do a search.
get the holley intank 12906 or 12916 FI, both flow 295LPH at 43PSIG.
12916 flows more at higher PSI than the 12906. depending on your BSFC and fuel tuning this should be more than enough for 450HP with larger injectors and slightly elevated fuel pressures. call the hollet tech line - they are very helpfull.
Old Dec 31, 2001 | 08:09 AM
SiRkid's Avatar
Default Re: High Flow Fuel Pump Question (rtype11)
i was wondering.whats the best pump with the max rev stuff?
hondata, 440's.boosting 10 psi max for now.
what do you think? stock?
Old Dec 31, 2001 | 08:34 AM
rtype11's Avatar
Default Re: High Flow Fuel Pump Question (SiRkid)
stockers will lean out and depending on age not very dependable at high pressure, get the hollet or simialr ugrade.
ps think I skrewed up the flow rate in my last post, think it 255LPH i keep forgetting. pls confirm
Old Jan 1, 2002 | 12:07 PM
cyan1de's Avatar
a little OT, but can i install a 255lph fuel pump and run it in my integra for about a month until i install my turbo? or will that be detrimental in some sort of way? i'm going to install AEM FPR, AEM fuel rail, and walbro 255lph pump... just wondering if i'll have problems until i get the turbo on.
Old Jan 1, 2002 | 12:13 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: High Flow Fuel Pump Question (cyan1de)
No, you wont have any problems. I did the same thing for about 2 months when I had my inline bosch.
art
Old Jan 1, 2002 | 01:25 PM
turbotypeR@SPEC's Avatar
25 Year Member
venom 100gph pump.HP733-515
Old Jan 3, 2002 | 12:05 PM
Anubyss's Avatar
I am hearing that some pumps are noisy and vibrate too much. What pump is quiet?
Old Jan 3, 2002 | 01:41 PM
bigTom's Avatar
Julio@Bisimoto
Oct 19, 2012 09:44 AM
EF'n Sedan
Apr 29, 2011 04:05 AM
1SlowSi
Mar 1, 2004 08:50 PM
M.K.C.
Nov 17, 2003 10:43 AM
Tuan
May 23, 2002 05:45 PM
