high compression + nitrous + OEM pistons..
JDM ITR .25mm overbored pistons... balanced/blueprinted+honed b18c1 block, skunk2 stage2 cams/springs/retainers/valves... could i put a 50 shot on and be safe without frying my pistons since htey're oem and i've got pretty high compression? (11+)
i was also told with the stage 2 cams, theyre pretty aggressive and the nitro will just fly by without having much effect... this true?
Im gonna vote YES, get it tuned properly, retard timing, proper fuel, a colder plugs and your 50 shot should be fine.
And as far as the cam lift goes, I dont think you would have to worry about that. The gas is still mixing and combusting with everything else.
slo97civic
Feb 23, 2005 08:14 AM
lke2drvgsr
29
Dec 7, 2003 08:53 AM
