High Compression Low Boost -- VS -- Low Compression High Boost
Old Dec 15, 2004 | 07:53 PM
  #101
Blaze45's Avatar
Brrraaaap!
Default Re: (b16coupe)
Doesnt more heat in the cc = more force pressing down on the pistion harder, providing more power? So if that is right (I just throwing this out there someone please educate me) then wont a higher CR yeild more heat when the combustion takes place because things are being compressed more, making more power in the end? or is this made up for on a lower CR engine by sheer amount of air in the cc? I suppose it depends on what octane your running, as well as timming...
tia
Blaze
Old Dec 15, 2004 | 07:54 PM
  #102
Tony the Tiger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe &raquo;</TD></TR><TR><TD CLASS="quote">
EXACTLY! On a 10.5:1 car you have no room for error, period. 14 pounds of boost, you get a tank of 93 that the gas station owner decided to cheap out on and cut 60/40 with 87 octane, on a warm day you're FUCKED. It really doesn't provide any advantage in a street car, so why take the risk?</TD></TR></TABLE>
You should know by now that it doesn't matter what compression you are running to be completely f*cked over by a bad tank of gas.
If your engine is tuned for ie: 91 octane, it doesn't matter what compression you are running to be screwed over by bad gas. Even an engine running a low 7.5:1 CR at 25+ psi of boost would still be destroyed if it was meant to run 91 octane.
It's all in the tuning. If I can tune my 11.5:1 CR at 12 psi of boost on pump premium (92 oct), I can also tune it for 89 octane or even lower if I wanted to. It's about power vs compression vs octane. Find a balance in between.
92GSREG
Jan 15, 2011 04:15 PM
MyEvo
Oct 6, 2005 05:14 AM
rb08
Aug 26, 2003 07:52 AM
NXAccordTO4B
Mar 20, 2003 09:01 PM
