High Compression Alternative
Old Dec 22, 2007 | 11:39 AM
D16SohcVtec's Avatar
Default High Compression Alternative
Motor: B16b
I was thinking about running a thicker head gasket to lower the comp down to around 10:1 or so. Keep reading about how thicker head gaskets mess up timing, are cam gears a must?
Am I better off runing OEM gasket and getting a good tune and hope it'll last for a while or is there some other sort of alternative?
Old Dec 22, 2007 | 11:41 AM
93supercoupe's Avatar
Default Re: High Compression Alternative (D16SohcVtec)
usaully when u mill the head, or install a thicker gasket, u need a way to compensate for the cam gears being closer/further from the crank.
So most likely u will need cam gears.
Old Dec 22, 2007 | 11:48 AM
Default Re: High Compression Alternative (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">usaully when u mill the head, or install a thicker gasket, u need a way to compensate for the cam gears being closer/further from the crank.
So most likely u will need cam gears.</TD></TR></TABLE>
I see, I didn't want to have to resort to using thicker gaskets and cam gears etc. 10.8 compression boost just doesn't sleep will in my head especially when IAT's start rising from hot summer days.
I'm also not too familiar with cam gears and cam timing, I never messed with any of those things.
anonnonator
Honda Civic (2001 - 2005)
Jul 16, 2008 02:12 PM
D16SohcVtec
Dec 31, 2007 11:00 AM
donnjuan2point2
Oct 2, 2003 01:12 PM
donnjuan2point2
Sep 30, 2003 07:28 AM
