high boost street tuning?
has anyone safely boosted 20psi+ on a street tune setup? I want to avoid the dyno as much as possible Or should it be tuned at a dyno at higher levels of boost? either with the hack or uber.
I've done street tuning before at 20psi in a built b20. It's not the safest thing in the world... so try to have a passenger to hold the wheel if you are driving...
What I usually do is let the customer drive the car past 15psi and I'll richen the **** out of the fuel map so it doesn't lean out. Then just pull up the datalog and make the necessary changes and repeat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project civic »</TD></TR><TR><TD CLASS="quote">has anyone safely boosted 20psi+ on a street tune setup? I want to avoid the dyno as much as possible Or should it be tuned at a dyno at higher levels of boost? either with the hack or uber.</TD></TR></TABLE>
20 PSI on "the hack" will last all of .0947 seconds. You better be prepared to run something better than that such as Crome, Uberdata, Hondata etc.
Drew Peacock
Sep 19, 2003 05:58 PM
