hi from germany
hi all ufff lots of ask..
I come from Germany and i driver a turbo civic ee9 vtec b16a1
MY turbo setup are not the best ,but low price and some fun
xs turbo kit
440rc injectors
walbro 250 gas pump
ecu with aem programm
oel interkuhler and other thinks for turbo setup..
germany turbo install is not simply. each 2 years mash one to car konntrolle tuev and exhaust gas test smoke test as in Japan, NO drive without controll from tuev..tuev is A one how controlls every 2 jears the BREAK and smoke from car and spreanks and wells.everything ..and to drive legal with turbo yo must register in vehicle paper and pay 500 dollar vor driving on street..
pics..
http://rapidshare.de/files/178....html
i have a big 3mm metall gasket for turbo with orginal 2 gasket over and under the motor block head , how much psi can i run ore drive??? 0,6 bar 6psi ore 0,9 bar 14 psi
gasket pic..http://rapidshare.de/files/17860889/03_1_b.JPG.html
and no tuning car shop in germany to test dyno hp??
is gtech ss a alternative and work right koreckt to see how much hp i have??
[IMG][/IMG]
Modified by TURKISHFORCE at 4:25 PM 4/12/2006
Modified by TURKISHFORCE at 4:29 PM 4/12/2006
Modified by TURKISHFORCE at 4:37 PM 4/12/2006
xs turbo kit
440rc injectors
walbro 250 gas pump
pics..
[IMG][/IMG] Modified by TURKISHFORCE at 4:25 PM 4/12/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing »</TD></TR><TR><TD CLASS="quote">I don't know how accurate the g-techs are, but its better then a butt dyno guess
youd be surprised how accurate they are if you get the wieght right
but they dont show knock so i wouldnt use them as a dyno.
TURKISHFORCE--
i had to pay for the same type of inspection when i lived in japan.
it was a real pain in the ***.
you may be better off tryin to find someone you can pay off to get it passed.
also
what are you using to tune it with?
or are you wondering who much psi you can run on the ecu you are currently running?
what size turbo are you running?
is the motor stock?
answer these and people will be able to help you easier
welcome
</TD></TR></TABLE>youd be surprised how accurate they are if you get the wieght right
TURKISHFORCE--
also
is the motor stock?
welcome
hi,
i use a manual boost controller totune up my psi
i know that i can run till 11 psi because the ecu is so modified (chip) but when i tried more the map sensor light/check engine light does NOT turned on
i have a t3/t4 turbo (standard xs turbo) and my motor is stock, have 440rc injectors,walbro 250 gas pump
oel interkuhler and other thinks for turbo setup (like i wrote above) and gasket with 3mm to reduce the blockpressure
i want to now how much psi i can try without damageing the motor
please infos-- thanks
do you have aftermarket (such as arp or golden eagle) headstuds? of you are you running stock head bolts? with studs you can run more boost without worrying about blowing a headgaskets
good luck
good luck
what ist this for a sound, on my turbo setup ,short ziiss-ziiss-zisssis ,this sound comes from wastgate or turbo how breaks weels turbine..?????is this normal , wen psi comes on 2 psi it is low nois and on 10 psi is lounder (like the video)..wenn i made blow off spring smooth it is nothing to hear, and hard spring it is louder ???the sound is not from blow off ..i have test without blow off and it mades still the same sound..
hire the sound what is this sound ?from blow off or turbo or wastegate?..
http://rapidshare.de/files/154....html
??turbocharger turbine (prob)??impeller?? how breaks???
blow off install is better, for turbo , and made no turbo damage?? my blow off is not 100% vakum low price blow off is bad ...xs blow off big....in germany are 2 kolben blow better??
http://cgi.ebay.de/NEU-Sequent...wItem
http://shop.wiltec.info/tabsho....html
my frend tell my , my xs turbocharger is to small to make more than 60hp??
Modified by TURKISHFORCE at 3:52 AM 4/14/2006
Modified by TURKISHFORCE at 10:21 AM 4/14/2006
