hey need help on turbo set up
Old Oct 9, 2010 | 04:36 PM
latino honda's Avatar
Default hey need help on turbo set up
I have an ls turbo in an eg si. The ls has wisceo pistons, eagle rods, 440 injector and have neptune as my tuning. The problem is that there is a miss fire which i can't understand why,
i got everything back in order my problem is when the car is cold it sound like **** (misfire)
when the car get to normal temp above 180, you mess around with the plug wires and then it will work fine a drive fine no miss fire. I've changed the spark plug, wire rotor and cap. Today i put my gsr dizzy and plug wires on my ls turbo and it did the same (misfire) so does anybody knows whats wrong
Old Oct 10, 2010 | 03:40 PM
Default Re: hey need help on turbo set up
ttt
Old Oct 10, 2010 | 05:54 PM
th3pwn3r's Avatar
Maybe you have your firing order wrong. Your question isn't easy to answer with the info you provided.
Old Oct 13, 2010 | 08:33 PM
injector wasn't plugged in all the way and timing was off a tooth plus i didn't have the resistor connect right is i have a dsm injectors but still have the hks blow off valve that doesn't sound right
Old Oct 14, 2010 | 01:31 AM
4dek's Avatar
u drunk bro?
Old Oct 14, 2010 | 01:59 PM
NinJa_FLiP's Avatar
lol.. i couldnt tell if he was making fun of himself or not?? so u didnt wire the injectors correctly? and ur saying that the hks blow off valve isnt "blowing off" right? please clarify
Old Nov 22, 2010 | 06:46 PM
Old Nov 23, 2010 | 05:17 AM
fcluddington's Avatar
mess with the ect or iat fuel and ignition corrections in Neptune. sounds like you only have problems when cold. I ended up adding more fuel in these parameters leave the fuel and ignition maps alone. btw what do you mean when you say mess with the plug wires are you switching them around ,, are u trying to reseat to make sure they are contacting
Old Nov 23, 2010 | 05:29 AM
just when im trying to reseat them but the only way it will work is if the car is hot or warm then it will run fine till then it just misfire my wideband doesn't read it
Old Nov 23, 2010 | 06:02 AM
Fc_v8's Avatar
Wow OP must be drunk or on drugs
Old Nov 23, 2010 | 09:11 AM
hey what do you mean
Old Nov 26, 2010 | 08:13 AM
ttt
MagicalMike
Nov 26, 2011 03:23 PM
atownludeh22a
Mar 13, 2011 08:36 PM
civicguy81
May 23, 2006 03:33 PM
djdc2
May 4, 2006 08:33 PM
