Heres a few pics of my built block (GE)
Re: (GEN2TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GEN2TEG »</TD></TR><TR><TD CLASS="quote">Nice pics. What bore size did you go with?
ls or gs-r? can't really see the code in the first shot.
its a LS, B18A bore to 84.5. 2.13L
Re: (mskibbz-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mskibbz-T »</TD></TR><TR><TD CLASS="quote">Did GE build it too or just sleeve it? What kind of turnaround was there if they did build it in house?
It's pretty btw </TD></TR></TABLE>
thanks guys, yeah everything was done at GE, Balance/Blueprinted, sleeved, bore and hone, pistons , rods, new crank 95 stroke
Re: (intekragsr)
Oh MAN!! SEXY!!!
I was like 2.13L THat's impossible with 89mm crank, so then i did the math for a 95mm crank, and it came up 2.13, so i was gonna say..stroker motor, and then i looked at the pics again, and i realized why the deck surface was so shiny.. DECKPLATE! Sexy!
I've yet to see a deckplate motor on boost! I eagerly wait results.
Im in the process of working out a trade for a deckplate from an HT member (dual cams)...what pistons/rods/crank?
Re: (intekragsr)
that looks alsome. What kind of r/s ratio is the motor running now? Also what compression? and what timing belt and water pump are you running?
Re: (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron »</TD></TR><TR><TD CLASS="quote">very attractive...how much does work like that set you back? any warranty from GE?</TD></TR></TABLE>
also like to know, what kind of pistons and rod setup did you go with, thanks.
Re: Heres a few pics of my built block (blufke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blufke »</TD></TR><TR><TD CLASS="quote">nice mike, finally got it back huh? cant wait to see it in person sometime(maybe get a ride )</TD></TR></TABLE>
yeah, its here bro, hhaah. let me know next time you're coming into town. We'll go for a spin,...(gotta break it in now )
Re: (T-Blaze)
Jsut curious how was your deck height on the block. On my deck plate mtor i had to take off .021 to get proper deck height and now my o-rings cant be used. Was yours on the money or did you have to do some work
Re: (Flamenco-T)
Man that is just plain out nuts. Boost ls motor alone make good power but add a deck plate with a bigger bore size, crank that just insane.
Re: (SiBirdie)
That setup looks awe - some. Maybe someday if I have too much money I'll do it just for the hell of it. Great to see it in the flesh instead of in my mind. Keep us posted on your project!!!!!!!
Edit: BTW $$??
What is this crap?
Re: Heres a few pics of my built block (boostedsol)
cool - i like how the tangs are built into the deckplate and reach out to the sleeves instead of the other way around.
it shore is purty. i dreamed of this buildup at one time.
