HELP: WTF is wrong w/ my engine?
Old Apr 1, 2003 | 03:58 PM
SpeedMonkeyRacing's Avatar
Default HELP: WTF is wrong w/ my engine?
Alright. Here's the deal. I just rebuild the motor. buttom block is GE 83.5mm sleeved (oringed and blah blah blah) w/ JE 9:1 pistons and eagle rods. Top was off a race car that only ran once on the dyno (pratically new). During the dyno run...the radiator fluid kicked back to the canister when its under boost (7psi). It has no signs of overheating, compression's good (170 all across), and good vacuum. Ralphy said that it's building up boost in the water jacket under boost. Does anyone ever encounter this problem before?
Jeff-
Old Apr 1, 2003 | 04:04 PM
bryan305's Avatar
Default Re: HELP: WTF is wrong w/ my engine? (Corporal-Jeff)
When you do the compression test, the motor's not running, correct? So is it possible the headgasket only leaks under boost like when on the dyno?
Old Apr 1, 2003 | 04:06 PM
boostaholic's Avatar
You may be lifting the head slightly in boost. Check the torque on your headstuds to make sure they haven't backed off any.
Old Apr 1, 2003 | 04:11 PM
93LSivic's Avatar
Default Re: HELP: WTF is wrong w/ my engine? (boostaholic)
Maybe the head was only on a race car on a dyno once for a reason
Did you bother checking to see if it was flat before you built the motor?
Old Apr 1, 2003 | 04:24 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Id say maybe yer head is lifting under boost also, just my $0.02
Old Apr 1, 2003 | 04:29 PM
boosted hybrid's Avatar
Default Re: HELP: WTF is wrong w/ my engine? (SIXTYdashONE)
Your head is def. lifting in boost. I had the exact same problem when my arp studs came loose. The coolant would shoot out of the overflow tank.
Old Apr 1, 2003 | 04:31 PM
ekb18c's Avatar
under boost and the radiator fluid goes into the revesouir sounds like a headgasket or your head lifted...Either, or, will cause that problem
Old Apr 1, 2003 | 05:28 PM
Default Re: HELP: WTF is wrong w/ my engine? (ekb18c)
well, we thought it was the headgasket that's why we replaced it w/ OEM headgasket from golden eagle. So you think the head's lifted huh? gonna have to look into that tomorrow to see if it needs to retorque.
thanks fo rthe help guys. we'll see what's up tomorrow!
Jeff-
Old Apr 1, 2003 | 05:32 PM
Default Re: HELP: WTF is wrong w/ my engine? (93LSivic)
hahahaha..it was checked by a machine shop along w/ my short block to make sure it's flush
Jeff-
Old Apr 1, 2003 | 05:36 PM
Default Re: HELP: WTF is wrong w/ my engine? (boosted hybrid)
i have arp head studs as well. gonna ask ralphy tomorrow to see if they can retorque it
Jeff-
MindLess311
Jun 10, 2011 04:45 PM
24boosted
Honda Civic (2006 - 2015)
Jun 8, 2008 09:03 AM
2 0 3
Jan 22, 2008 07:42 AM
legendboy
Aug 17, 2005 06:49 AM
Drew Peacock
Sep 19, 2003 05:58 PM
