HELP:what camS shld i use??
Old Jan 19, 2011 | 09:45 AM
travis91's Avatar
Default HELP:what camS shld i use??
i have a b16 with 8.5:1 pistons and eagle rods, im shooting for 500ish hp. couple people say gsr cams and others say itr cams? whats the best cam to use??
Old Jan 20, 2011 | 10:02 PM
travis91's Avatar
Default Re: HELP:what camS shld i use??
anyone?!!!
Old Jan 20, 2011 | 10:04 PM
wantboost's Avatar
Who is Mr Robot?
post your complete setup, then maybe we can figure out how to help you
Old Jan 20, 2011 | 10:13 PM
jDMJeRk's Avatar
either will get the job done in my opinion. How much money you have will be the biggest factor imo.
Old Jan 20, 2011 | 11:12 PM
rev-speed's Avatar
500whp on a b16 will require a 35r+
so stg 2 cams will be best to wake the motor up
Old Jan 20, 2011 | 11:33 PM
cibao2ner's Avatar
pro1s...they will help improve the midrange torque on the b16...pro1 have stage 2 vtec lobes and better primary lobes than the old tuner 2s..
Old Jan 21, 2011 | 07:04 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
That compression is crap, things not a DSM, lol!
Good luck with that.
Old Feb 8, 2011 | 05:59 AM
travis91's Avatar
we'll see if its crap, i only need ic piping, and injectors to fininsh and i will post numbers
Old Feb 8, 2011 | 06:05 AM
kyden's Avatar
bigger cams depend entirely on your setup. but itr cams are universally the best oem.
that car is going to suck to drive out of boost.
Old Feb 8, 2011 | 06:15 AM
NY GsR's Avatar
(equal length manifold? victor x or similar intake? 35r or bigger turbo?- i would use pro1s.)
itr cams if anything else
Old Feb 8, 2011 | 06:26 AM
DeLucia's Avatar
ITR
Old Feb 8, 2011 | 06:29 AM
sanman000719's Avatar
the idea of low compression on turbo cars is busted and will hurt you more than help you
most turbo cars are 10:1 now a days for a reason
Old Feb 8, 2011 | 11:25 AM
EsotericImage's Avatar
Retired Moderator
With that low CR, you can bump up the boost for better CR. I would look to a stage 1 cam, but If it were me, I would get a new TB and port match it with a new IM to help with flow.
You dont want to over cam cuz with that low CR it will run like ****. Some simple stage 1 cams with boost will wake up the power.
IC piping >> http://www.velocityshop.com/product/...ivic-_363.html
Roman--Vti
13
Jul 26, 2005 01:51 AM
jsteezy1290
23
May 15, 2004 06:38 PM
weraider30
Feb 3, 2004 05:12 PM
wrXtian
Mar 9, 2003 06:07 PM
EF8SIR
Jan 30, 2002 11:30 PM
