Help w/turbo filter issues recommendations?...
Old Nov 3, 2006 | 04:43 PM
Samuels's Avatar
Default Help w/turbo filter issues recommendations?...
I'm having some issues with my turbo filter it sounds like its closing up or something once i get over 10 psi.. It makes a terrible sucking whoosing sound and seems to kill power but its defintely not like a cai sucking sound.. When i take the filter off no sounds and it runs great.. I was thinking of getting alil piece of pipe in between but my inlet is on the drivers side and the filter fits with about 2" to spare before the body so thiers not alot of room..
I searched and found a guy useing a filter with a metal ring in it like mine so i'm getting rid of it regardless because it tore up his turbo.. Mine is called a poweradder and cost 30 bucks nothing special just a autozone/pepboys special
The car makes 370hp on 18 psi is that to much for a normal filter??
What are you guys running or would you suggest i don't mind spending the money just don't wanna dish out 50 bucks for a k&n and its still doing the same thing??
anybody had this happen to them??
Old Nov 3, 2006 | 07:21 PM
a1320addict's Avatar
Default Re: Help w/turbo filter issues recommendations?... (Samuels)
I've been using a K&N for almost a year and a half with no problems.
Think of it this way that $50 is going to save you an exponential amount of money down the road if you don't run a filter, or a quality filter in your case. I mean, unless you're looking to let your turbo eat up the filter
Old Nov 3, 2006 | 07:36 PM
Samuels's Avatar
Default Re: Help w/turbo filter issues recommendations?... (a1320addict)
i don't mind paying the money at all i just wanna be sure to fix the issue..
Old Nov 4, 2006 | 10:38 AM
Samuels's Avatar
bought a k&n filter today its doing the same thing...
Old Nov 5, 2006 | 05:46 PM
Samuels's Avatar
any ideas if its normal cool but it feels like its killin power and sounds like its sucking the filter thru the turbo lol..
Old Nov 5, 2006 | 07:23 PM
WFboostinEK's Avatar
I'm running a K&N Filter on my car with no problems at all....im running the 3" short filter, ill get you the part number when i get to the shop tommorow.
Old Nov 6, 2006 | 07:58 AM
The part number for the one i use is RU-3700...look it up on k&N's Website
Old Nov 6, 2006 | 03:33 PM
Samuels's Avatar
Default Re: (WFboostinEK)
u don't hear any crazy sound coming from it??
i take the filter off and it sounds fine.. it sounds like my turbo is starving for air or something and trying to suck the filter thru....
Old Nov 6, 2006 | 03:41 PM
93CX's Avatar
Default Re: (Samuels)
In my experience with my turbo setup, filters rob power. I've tried K&N, AEM, and even an APC foam one, and nothing comes close to open inlet. However recently I have been running two layers of mesh with a hose clamp around the inlet and it sounds and pulls almost as hard as open inlet. The downside is that it reduces surface area of air that can come into your turbo according to some turbo gurus. There are 3 options, filter, mesh, and open, they all have their pros and cons.
Filter :
Quiet
IMO somewhat restrictive
Safe
Mesh :
Loud
Allegedly restrictive
Mildly unsafe
Open :
Loud
No restriction whatsoever
Very unsafe
Old Nov 7, 2006 | 07:53 PM
Default Re: (93CX)
Good analogy.....
Old Nov 9, 2006 | 03:55 PM
Samuels's Avatar
Yeah, I understand all that bro i run no filter at the track.. But i work at a rock quarry and occasionally drive my car in thier so a filter is necessary its just pissing me off.. IT SOUNDS LIKE THE FILTER IS GONNA GO THRU THE TURBO IT MAKES A CRAZY SOUND..
Old Nov 9, 2006 | 05:16 PM
J3's Avatar
J3
I just switched over to a K&N from my old mesh screen, it feels like it took away a few HP but its def better for a DD.
miahjera04
Dec 14, 2017 04:06 PM
jdmcivic2fast
Jun 22, 2011 07:32 PM
slowteg550
Jul 24, 2006 01:57 PM
madman604
May 27, 2003 02:13 PM
Elite Hatch
Nov 24, 2002 05:04 PM
