help w/ pssssssss sound
i just got a profec B boost controller and boost gauge hooked up, and now when my car is running, in the interior, i hear a slight psssssssssssss or hisssss that is constant and is very quiet...is this normal? what is it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shming123 »</TD></TR><TR><TD CLASS="quote">no, the boost gage is reading 7psi, which is where i want it set at....could it still be a vacuum leak?</TD></TR></TABLE>
uh... you set the b/c at 7psi but whats your vacume at idle at?
like sitting in the driveway... not touching the gas...
Im willing to bet it's a vacume leak on one of the connections to your boost gauge or boost controller that got pinched, cracked or is leaking....
I still think you have a vacume leak.... if you didnt hear it before the boost controller install then it has to be the culprit... but -17 to -20 sounds about right if your at sea level...
mkinpwrat12g's
Sep 29, 2005 02:33 PM
