help with turbosmart dual stage boost controller problems??
Old May 10, 2007 | 05:16 PM
Samuels's Avatar
Default help with turbosmart dual stage boost controller problems??
Ok i took out my inline pro manuel to try this boost controller out from a buddy so i can run powerstreet on drag radials.. I was hoping to be able to run 12-15lbs in 1st gear and possibly 2nd, then 23lbs in 3rd,4th,5th.. On 23 psi and on my drag radials i spin violently and can't manage but a low 2.1 60ft on slicks its butter..
Right now my acrobat reader or whatever is'nt working right to look at the instructions from turbosmart.. I basically hooked up the blue wire to power and the brown wire to ground into the switch.. My wastegate spring is 10lbs, so with the low setting turned all the way down i'm stilling getting 15 psi with about 1 psi higher in 1st and 2nd.. I cranked the higher boost setting way up and it reads the same number.. Here is the tricky part with the wiring unhooked but the vacuum lines still hooked up my boost will spike like my WG don't work and i gotta let off quickly.. Put my inline pro controller in its butter.. I did hear to run the vacuum line to vacuum before the TB but i got mine off of the vacuum manifold from the IM vacuum source..
Any have 1 of these or can help me out??..
Old May 11, 2007 | 11:23 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: help with turbosmart dual stage boost controller problems?? (Samuels)
Your BC def needs to be hooked up b4 the TB! I don't know anything about there BC so I cannot be of anymore help.
DL Adobe Reader again and re-install it: http://www.adobe.com/products/reader/
ericstambaugh07
Jun 23, 2007 09:04 AM
SPOOLED
May 23, 2005 07:51 AM
Mad Cow
Jan 29, 2005 06:52 AM
Mag00n
Jun 3, 2004 09:21 PM
RyanAutry
Nov 6, 2002 07:08 PM
