Help tuning Uberdata!
Setup is:
-2000 SiR
-converted to OBD1 with P28 and Uberdata
-DSM 450's
My problem is I'm having a really high and rich idle. It idles at 950rpms and the A:F reads 10.6. I've leaned it out A LOT and it's still like that. I've also set the IACV tab all the way to the right but no luck in bringing the idle down. Any ideas/tips? Thanks.
-2000 SiR
-DSM 450's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr »</TD></TR><TR><TD CLASS="quote">its probably from the injectors, not uberdata. mine did the same thing sometimes w/ dsms</TD></TR></TABLE>
sam, what did you do to correct that?
didnt do anything. mine idled at like 2 grand for about 30 seconds when cold. dont know why. couldnt fix it.
as for your uberdata problem send me your map and il look at it. if its for an LS i will send you my map and you can try it, it idled dsm 450s like stock once warm
sam
sam
i checked it out. theres no reason for you to be running rich. lean out the 20 and 17 columsn and se eif that helps. you should be able to idle 370-720 injectors with those fuel values. its pretty easy to idle injectors... i once put in a 240cc map for myf riends 550cc car and it idled em
sam
sam
jaxx4k
Sep 2, 2005 07:30 PM
