help throwing code for map sensor
Old Aug 11, 2003 | 06:35 PM
SDT Project EF's Avatar
Default help throwing code for map sensor
ok setup. 1989 civic si d16z6 turbo running 7-8 psi with 450s and using v-afc. When reving past 4 grand and making boost some times check engine light comes on for map sensor. Does this mean my map sensor is reading boost? Do i need to run a check valve to eliminate this problem? My friend says the V-afc should make it so i dont need to run check valves. Could this problem be eliminated with dyno tunning? Help me please. thanks in advance for any helpful responses.
Old Aug 11, 2003 | 08:07 PM
the kid's Avatar
Default Re: help throwing code for map sensor (SDT Project EF)
yes get missing link it works better than check valves looks nicer.
Old Aug 11, 2003 | 08:45 PM
ttt
Old Aug 11, 2003 | 10:15 PM
project dc2's Avatar
up for tihis pooor sucka
Old Aug 12, 2003 | 12:57 AM
ScrapinSi's Avatar
what are your AFC settings at? have you tuned it? If you dont have the AFC lean enough, it wont trick the MAP sensor enough...
Old Aug 12, 2003 | 08:20 AM
Default Re: help throwing code for map sensor (ScrapinSi)
help this poor shmuck out
Old Aug 12, 2003 | 08:28 AM
Sinner's Avatar
my map sensor light came on when I ran stuiped rich. I even swapped sensors I couldnt figure it out until someone told me to lean it out.
Old Aug 12, 2003 | 10:08 AM
the kid's Avatar
my car is ob2 with no missing link or check valves on it as soon as the car reads boost it starts fuup every time it throws a code yor car is in limp mode thats not good just buy a freakin missing link and problem solved no question asked
Old Aug 12, 2003 | 02:23 PM
Default Re: help throwing code for map sensor (the kid)
thanks guys except for that punk project DC2 I hear that guy is rollin with an intercooler but no turbo what a poser.
Old Aug 12, 2003 | 05:43 PM
"u start talking that trash n we'll pull your car, knowing nothing in life but to obee legit,dont try me boy cuz i aint said ****"
turboedd15b
Jul 18, 2005 07:58 PM
lscivc
Feb 19, 2005 08:04 AM
silverbulletgsr
May 20, 2004 08:24 AM
16STCRX
Oct 15, 2003 02:35 PM
Blackcivic1
Nov 4, 2002 04:03 AM
