Help with squeaking noise
Old Aug 2, 2002 | 11:37 PM
shadowdawn's Avatar
Default Help with squeaking noise
I recently changed my belts less then 2 thousand miles ago.... had no problems (car has 43k on it now) I changed them myself with a friend so I didn't have whatever tool it is to check tension or whatever but everything is fairly tight with little or no give at allwhen pulled/pushed on.
However when I drive around from stop to go I hear .5 second squeaks while I accelerate in a random patern. VERY high pitched squeaks like a belt I guess would make... only when I accelerate from a stop can I hear it, a few times while in 1st and almost ALWAYS when it shifts from 1st to second and then it putters off because I come to a cruising speed.
Today before work I tightened the p/s belt as much as I could because it seemed looser then the others... that didn't do anything.
Can anyone help me out? Is it definatly my belts or could this high pitched squeaking thats coming from the engine bay be something else.... any suggestions are welcome. Thanks
Old Aug 3, 2002 | 01:30 AM
CM-R's Avatar
Default Re: Help with squeaking noise (shadowdawn)
alternator belt needs to be tightend.....
Old Aug 3, 2002 | 11:27 AM
shadowdawn's Avatar
Just wanna get more opinions on the topic...
Old Aug 3, 2002 | 05:49 PM
shadowdawn's Avatar
Default Re: Help with squeaking noise (CM-R)
Well I already tightened the p/s.... also checked the alternator and you CANNOT tighten it anymore, its at the far end all the way to the firewall with no more play to get more tension on it. So I loosened it a bit thinking its too tight and drove around..... did nothing. Then I tightened the a/c belt a bit cause it seemed a tad loose.... drove around and still nothing..
Any more ideas?
Old Aug 4, 2002 | 09:48 AM
shadowdawn's Avatar
ugly.
18
Jan 16, 2010 08:47 PM
Zuerst
Jan 13, 2004 11:33 AM
stRtypR25
Sep 26, 2002 03:01 PM
shadowdawn
Aug 8, 2002 07:36 PM
