Help with SpeedPro installation
I'm using a SpeedPro bank to bank ECU along with the Honda specific wiring (not the generic GM style harness) harness on a 97 LS. The IAC connector on the wiring harness has 4 wires, but the IAC connector on the intake manifold is only 2 wires. Is there a specific IAC connector needed to run with the SpeedPro or is there a way to rewire it?
Also, the SpeedPro came with a 4 plug injector wiring harness but it doesn't specify which plug goes to what injector. Each plug has a common red wire and the other 4 are a different color. Thanks for any help!
make sure you get the timing matched on the timing gun to whats indicated on the timing map before you go driving around. if its totally off play with the crank reference angle parameter. off of memory the # should be somewhere around 56 degrees + or - 5 let me know how it goes.
they have an adapter you can buy to run the gm aic. it cost about 75 bucks you can buy it at force-efi.com
I will give you a freebie on the injector question
injector 1 = brown/red
injector 2 = black/red
injector 3 = green/red
injector 4 = yellow/red
Oh and the car will run just fine without the iac valve. I don't use it and still have a stock idle.
[Modified by GSRev, 11:31 AM 9/22/2002]
is #1 coming from the pulley side or distributor side?? I dont know if i did mine right, but my yellow/red ended up on the distributor side.
Alex right?? hey this is Dandee, Im trying to get my wiring done, u think u can give me a hand??
[Modified by JiSATSU RaceR, 7:32 PM 9/22/2002]
LOL!!! Come on Dandee.......you know the cylinder order! What's up Alex, how's it goin?
B_Swapped93
Mar 7, 2014 04:54 PM
alexdelsol94
Mar 2, 2009 06:32 PM
