Help smog required on built motor with jrsc
my 98'' integra gsr is up for smog this nov. and i know it wont pass and i need to go to a test only place heres the setup! does anyone know what i could do or have any conections lmk asap thanks.
gsr head and block
jrsc 5 psi
sk2 pro 1 cams
usdm itr pistons
rc 440 injectors
comptech ice box intake
jdm 4-1 itr replica header with heat shield
buddy club spec 3 catback with magna flow muffler tip
hondata s100 ecu!
gsr head and block
jrsc 5 psi
sk2 pro 1 cams
usdm itr pistons
rc 440 injectors
hondata s100 ecu!
find someone that you can pay to pass , your car will never pass being obd1 now. thats what sucks about obd2 cars switching to obd1 i have the same prob in my 96 ek im just going to pay someone to pass it
I live in Ohio and have the same problem with a 2000 Prelude and Hondata 300. I went to the state run E-check and was told that I could make a list of the modifications along with pictures, take the information to the license bureau, and get a special license plate that would exempt the car from e-check. It will cost more, but the only other solution is to put the electronics back to stock obd2. Maybe you could give that a try, but California, probably not.
JRSC has carb cert. Cams are hidden. Comptech ice box has carb cert. JDM replica w/ heatshield will look stock.
All obd2 cars are required to have the computer checked by the smog machine, not 2000 and up. Only way you get away without the check is if it is over 15000 lbs GVWR. Otherwise your screwed. And any smog tech that doesn't know what a supercharger looks like needs to be caught. Your only chance is to either pay someone to pass it which would be taking a risk for them because the smog machine reads the vin from the ecu but it does not match it up right away.
Or just take the supercharger off and smog it then put it back on? WHy pay someone 300-400 to smog the car?
Actually, in California they are only supposed to hook up the port scanner on 2000 and later cars. The 98 should be able to pass if the cat is good and the emissions are clean, and the tech doesn't notice the illegal parts.
I missed the intake, unless it has a eo# it will fail. The header will need a eo#, Injectors would to as it modifies the fuel system cams and pistons wont matter because you cant see them. Adjustable cam gears are going to have to have an eo# very soon as well. CAtback doesn't matter as long as the cat is there and the second o2 is there.
I don't know where you guys are getting your info from but no smog laws were changed last year for 98 and older cars or for test only stations. I know because I own three of them. Every time you go to get your car smogged at any station they will hook up the obd2 if it is under 15000lbs GVWR. I looked on the jackson website and the kit is legal under eo# is d-344-11 go to this link http://arb.ca.gov/msprog/aftermkt/de...o/D-344-11.pdf
Put the cat on and YES hook up the rear O2, I look for everything on all honda's and acuras as I am sure most techs do. Try to make it as stock as possible and put stock ecu back in with the stock injectors. It wont run with the big injectors in it and it wont blow up because your not in boost on the dyno, the ecu has to have fuel control and to be in closed loop on the dyno. Don't work about blowing it up just don't stomp on it.
Everyone wants to get past the smog, well if you make it look stock and have eo#'s what can they say? Print that link out and give it to the smog guy before he tests the car. If your really worried about it get a pre-test. The state doesn't care if the car fails they just want it fixed.
Don't say anything about the cams and they are not going to check the timing because the emissions label does not require them to on a 98. Pistons would only create nox if the compression was really high, but as you used us itr pistons it will be fine, I doubt those cams will do anything either.
I got all my stock stuff back in, thats my stock header, cat, injectors and ecu now im throwing codes
p1259- vtec system malfuntion
p1337- crank shaft speed sensor no sigal
p0141- secondary o2 sensor circuit malfuntion.
now i have no idea why i would have a vtec malfunction it worked fine when it was the way it was before with the hondata ecu and injectors ect..
and i cant remember why my crank sensor isnt hooked up i think it was because i was going obd1 so it wouldnt read anyway i think and also i think i have a weak connection on the wiring job i did on the second o2 sensor any input will help me even tonight cause i want to try smogging it tomarrow!
In Oklahoma we don't even have vehicle inspections and the several times I've been pulled over the cops don't even look at anything. Cali is cool, but not if you own a modded car.....
