Help Running Lean
Old Jul 5, 2014 | 07:38 PM
Natural Aspirations's Avatar
Default Help Running Lean
I am pretty much stumped by this recent issue at the track. Regardless of boost pressure or gear my car runs lean above 7300 RPM at the track when it did not on the dyno previously.
I am using
ID1000cc Injectors
DW300LPH Pump
Fuelab Regulator @ 50 Base Pressure
SUNOCO 110 OCTANE over 1/2 tank fuel
Stock lines to the bay, 6an from the hardline through a fuel lab filter to a GE rail.
The fuel pump is rewired and I have verified that the pump receives 14V at 80PSI with engine running.
My first thought was that the pump was unable to supply enough fuel but I noticed the engine running lean at lower boost pressures as well.
Another odd finding was that when increasing fuel pressure at idle caused the engine to idle lean, 70PSI made the idle AFR increase from 14.5:1 to 16.5:1
ashb82
Engine Management and Tuning
Jul 13, 2011 06:21 PM
shlude1
Mar 13, 2008 07:01 PM
racerx023
Sep 7, 2006 07:36 AM
onefstek
Dec 5, 2005 10:29 PM
bluesi00
Sep 7, 2004 10:20 PM
