help. which resistor goes to which wire.
Old Mar 15, 2003 | 12:43 PM
turbod16y8's Avatar
Default help. which resistor goes to which wire.
hey guys help me out which resistor goes to which wire. thanks. theres only one black with yellow stripe.
Old Mar 15, 2003 | 01:41 PM
turbod16y8's Avatar
Default Re: help. which resistor goes to which wire. (turbod16y8)
i forgot to tell u that these wires are from a clip.
Old Mar 15, 2003 | 01:45 PM
liam821's Avatar
on aim..
Vi3Tl3oY: liam
Vi3Tl3oY: u there?
liam821: i could be...for a price
liam821: ;-)
Vi3Tl3oY: https://honda-tech.com/zerothread?id=443803
Vi3Tl3oY: hah sup
Vi3Tl3oY: can u help me out
liam821: you want the yellow/black wire
liam821: its the wires that are all the same color on each lead
Vi3Tl3oY: theres only one of them
liam821: what wires are those?
Vi3Tl3oY: can u see the pivture
liam821: yea
liam821: what are those wires from?
Vi3Tl3oY: ohh clips
liam821: what clips?
liam821: you want the resistor on the yellow/black wires on the factor connectors
Vi3Tl3oY: they came with my injectors
liam821: i have no idea
Vi3Tl3oY: yes but only one clip has the black and yellow
liam821: what i would do is...look on the stock clips
Vi3Tl3oY: ok
liam821: find the yellow/black and remember which side the clip its on
liam821: and then use that same wire on the new clips
liam821: the same side
Vi3Tl3oY: ok
liam821: your connect have to cut off the stock clips and wire thoughs on
liam821: thoses*
Vi3Tl3oY: should it be ok if i install the smc and 450 first
liam821: so just make sure the left side of the clip does to the same wire as the honda left side clip wire ;-)
Vi3Tl3oY: before turbo?
liam821: yep
liam821: i passed smog with no turbo but 450s and an afc ;-)
Vi3Tl3oY: cool
hehe
liam
Old Mar 15, 2003 | 09:29 PM
turbod16y8's Avatar
Default Re: help. which resistor goes to which wire. (liam821)
ttt guys i need your help....
[Modified by turbod16y8, 10:31 PM 3/15/2003]
Old Mar 15, 2003 | 11:17 PM
LJR-LUDE01's Avatar
do your clips look like these?
if so then just use these diagram
I'm not sure how it is in your car but in my prelude I have it like these...
Old Mar 16, 2003 | 12:13 AM
sparkz's Avatar
Default Re: help. which resistor goes to which wire. (LJR-LUDE01)
the wires that have the stripe on it recieves pwr from the source and the other nonstriped wires goes to the ecu. even if you flip the wires backwayrds, the injectors would still work
jdm206
10
Apr 22, 2007 02:40 PM
Skinflute22
Jun 1, 2005 07:06 PM
Timmay
May 20, 2004 07:48 AM
importimage
Oct 31, 2003 09:07 PM
